Re: Dino's 42" Pizza Oven Starts
Thanks for the reminder Christo, I get so dissapointed at some joints and cuts. I need to remember an "ugly" dome will perform just as good. And it's ugly for me as I try to wrap my head around the inner arch and my outer arch being at a wider angle. I have to cut a 45 deg angle across my arch walls 4th row to start the curve. I think I'll try to finish the inner arch on its own THEN tackle the outer arch and brick-length wall between where it will be the vent width opening eventually.
Thanks Ken, I love looking over your pictures regularly they really are helpful. Oh and everyone else too. It's great to have so much visual aid. Tying in the walls was a bit tough but I'm happy now that it's mostly done. Like Christo says, only I see any "inconsistencies".
I noticed Breven and TheBadgerBuild went 3 bricks up and started the arch. Others went a full 4 bricks, about 10" high on the door edge. I assume you all went 12 or 12-1/2" high to the middle of the door. I'm leaning toward 3 high or 7-7/8" for mine, then arch to 12" or 12.5" in the center. (63% of my 20" dome is 12.6"). My opening is 20" wide so if I start lower at the edges, it should be similar to a 19" opening with 9" sides.
The mental calisthenics required to build this is just practice for learning percentage of hydration and protein/ash ratio in pizza dough when I finally get to making pizza! I'll be ready by then
thanks, Dino
thanks, Dino
. Here are 2 pics of my "problem" but I think I've got it licked. The 1st pic shows from the front how I can complete my inner arch like normal, then my outer arch will sit on a brick cut in 2 angles .....................
-Dino
The angle of the brick on each course is where I paid most attention. It never appeared to be enought angle on the low courses. My 42" pompeii will have 20" interior height. Though I'm not cutting my brick bottoms at angles (only the sides), I am using expensive mortar to set the angle and maintain small mortar lines on the inside. I used a porpedo level with digital readout and angles generated from CADD. So far it has worked well and I'm only off 3/16"
