Re: Dino's 42" Pizza Oven Starts
Thanks for the reminder Christo, I get so dissapointed at some joints and cuts. I need to remember an "ugly" dome will perform just as good. And it's ugly for me as I try to wrap my head around the inner arch and my outer arch being at a wider angle. I have to cut a 45 deg angle across my arch walls 4th row to start the curve. I think I'll try to finish the inner arch on its own THEN tackle the outer arch and brick-length wall between where it will be the vent width opening eventually.
Thanks Ken, I love looking over your pictures regularly they really are helpful. Oh and everyone else too. It's great to have so much visual aid. Tying in the walls was a bit tough but I'm happy now that it's mostly done. Like Christo says, only I see any "inconsistencies".
I noticed Breven and TheBadgerBuild went 3 bricks up and started the arch. Others went a full 4 bricks, about 10" high on the door edge. I assume you all went 12 or 12-1/2" high to the middle of the door. I'm leaning toward 3 high or 7-7/8" for mine, then arch to 12" or 12.5" in the center. (63% of my 20" dome is 12.6"). My opening is 20" wide so if I start lower at the edges, it should be similar to a 19" opening with 9" sides.
The mental calisthenics required to build this is just practice for learning percentage of hydration and protein/ash ratio in pizza dough when I finally get to making pizza! I'll be ready by then
thanks, Dino
