Re: Dino's 42" Pizza Oven Starts
I think I've cut all my vent transition bricks and stacked them to see how the anchor plate will work. In this pic, you can I'd like to cut an "L" shaped brick like some others have done.
If I do this all the way around:
1) Do need to use concrete bolts and screw in the 4 holes in the corners of the Simpson Anchor Plate? (I would like not to do that)
2) Can I just mortar the anchor plates flange, above and below it, and NOT put a layer of the FB insulation blanket between my anchor plates flat flange and the brick below it?
thanks, Dino
thanks, Dino
