Dino's 42" Pizza Oven Starts
  • Re: Dino's 42" Pizza Oven Starts
    Thanks for the link info on the bricks. I'll take a look at the choices again. My biggest concern would be mixing different brick types in the dome structure, but using the Pacific as the floor and the Muddox in the dome seems to make some sense.
    Chris
      Hi Dino
      I see that you cut the tops of your soldier course. What angle did you use and how did you come up with it? This is the next phase of my build and I want to make sure that I don’t make the angle too steep.
      Regards
      Larry
        Hi Larry, I cut my soldier course 1-3/8" down on the inside. Now remember: that is with my soldier course ON THE OUTSIDE, NOT on top of the oven floor. I don't know which way you are planning to do it but with my full brick on the outside, the soldier brick has a 5-1/8" rise that faces the inside of the dome (equals a 9" brick when you add in the 2" FB board I used under it). And doing this on a 42" oven floor, it seems to me to work out great. If I had a slightly smaller oven, I might then cut the soldier course with a less steep angle (not that I think my angle is sharp or steep at all.)
        Many on this forum use half bricks for the soldier course and it works fine. I thought with a 42" oven, that having some soldier course hieght was good for having larger roasting pans (Le Cruset style stuff) but now realize that you never put more than 1 or 2 tall pots in the middle for overnight slow cooking so it all works out.
        Hope this helps out, looking forward to seeing your oven build! thanks, Dino
        My Oven Costs Spreadsheet
        My Oven Thread
          Thanks Dino
          I just wanted to make sure that I was in the ballpark. I'm also putting the soldier course outside the oven floor and I'm building a 42" oven. I calculated approx. 5 1/4" rise. I've been sitting here for weeks with a pallet of firebricks wringing my hands not wanting to make a mistake. I've sketched out the oven on paper over and over. Thanks again this puts my mind somewhat at ease.
          Regards
          Larry
            I think I've finished ALL the steel stud framing I plan on using. Overhanging the front gable 12" in front and 6" in back really threw me. I thought it was obvious but took more time to make sure it transferred the load to the roof members behind them. I installed a "double-ridge" that tied it all together. Here are 2 picks, I'll take a few more when I clean up the area. i've got a peek-a-boo door in the rear that's really nice for the electrical I'll post soon.
            I've been buying my cement board, roofing plywood, black slate, copper flashing and proper screws to drill through durock & plywood, and then drill into steel studs. I've also had fabricated a custom flashing for the dura-vent made of copper to use on my slate roof. It's all very exciting but I've also got 10 people over this Sat for a pizza fest and swim, so the enclosure is going slower but hey, firing up the oven is an exciting event.
            PS: I feel sooooo sloooooow as I see others on the forum introduce themselves, build and finish thier ovens and start their 1st fires in the time it takes me to post 2 of my longer FB Forum posts. What's up with that?
            (The 2nd pick are the BEST roasted pork ribs I've ever had. Had NO idea they would come out this much better than my regular oven...which were great to begin with, man, I love WFO cooking!!!) Cheers all, Dino
            My Oven Thread
              Nice progress! Its a shame to cover up all that metal framing.
              That slate/copper combination will look stunning. I still wonder if I made the right decision with the flat roof.
              I feel sooo slow, too. But then again I've been at this 2 years longer than you. Quality takes time and it's no fun working on a hot oven!
              Christo
              My oven progress -
              sigpic
                Dino, great framing and ribs. What's the recipe (ribs)? I too have noticed a surge in oven builds which is great. I gave up the race long ago. I'm worried I'm going to finish and have nothing else to do...
                Bill
                Oven Build: https://goo.gl/photos/rN6FhFSS2jzwfQuB7
                Oven cooking: https://photos.app.goo.gl/1vmPg7XXSbMwhdnD6
                  Dino,
                  I was just thinking how fast your build was going! You've now officially passed me! I'm also working on those overhangs. Could you please post some detailed photos? What is the "double ridge"?
                  Do you plan or think there is a need to have vent in the enclosed oven? If so, where do you plan to put one?
                  Also, give us details on the ribs. I just ruined a slab last night. My apologies to the pig, who died for nothing. I made pizza the night prior, threw in some ribs the next day, added a small piece of wood to rekindle some smoke, partially closed up, and turned it into a dried piece of char! I didn't measure the temps (to lazy to change the battery on my IR gun), and think I underestimated the amount of retained heat I had.
                  Mike - Saginaw, MI
                  Picasa Web Album
                  My oven build thread
                    Thanks Bill, the ribs are done oven roasted style, not bbq or tomato based. The slab is in shallow glass dish with nothing but 1/4" of water and quartered onion and celery, salt & pepper, touch of olive oil on top and the high heat of the oven (600*) seemed to sear them on top, crisped the fat so it was all edible and the meat kept it's pure pork flavor with slight smokiness, crispy but still moist inside.
                    Christo, I know what you mean about the steel framing so I put in a door in the rear for the electircal transformer and I can see my stud work anytime!
                    Mike, Sorry about the dry ribs. It sounds like they stayed in too long. I've been scorching 75% of my pizza bottoms/middle but think I've got a solution last night: mop the floor if it's over 700 or keep my dough discs not so thin.
                    RE: oven enclosure vent, yes, I think I have to have one. My roof will be black slate and that gets hot. Also, I'm going to use roofing plywood under it and there is a remote chance of delamination on the plywood if it gets too warm. I'll put in an eve vent towards the rear on the side and a gable style vent in the back that nobody sees. What are planning for roof? Below is a pic of the 3 vents I bought. I'll think I'll use the little round one at the top. Also, see my other fun toys: the slate and my custom copper vent collar I had made.
                    Thanks Dino
                    My Oven Thread
                      The slate roof and copper are going to look great. Can't wait to see how the roof is installed.
                      Bill
                        Dino, the oven looks outstanding. I love the copper and slate look. It looks like you are going to put lights on the sides as well. I hope I don't regret not doing that, but I have my oven in a small area and didn't think I would need them.
                        Looking forward to seeing that slate and copper trim!
                        Scott...
                        Smuth's Build
                        www.openhearthovenworks.com
                          That is a nice looking build you got going Dino. If the wires are for lights, that is a great idea. I did not run lights and I have to resort to a puny LED magnetic light that is not nearly bright enough. I'm trying to figure out how to run lights without having to do too electrical work.
                          Your roof with the flashing are going to look fantastic.
                          My WFO project: http://picasaweb.google.com/stevprin/WFOSmallPhotos#
                            Thanks Bill, Scott and Steve. Steve, I was just going over you web album earlier today and enjoyed your build. Scott, your rectangular lights in the soffit look great. I'm only installing 2 recessed, low voltage small can lights in the front. I'm just running the LV cable around the frame so it looks like they are in the rake eves but aren't.
                            Bill, I'm with you, can't wait to see how I do it either. The things you learn about building a WFO. Last year, I never would have thought I'd be reading and asking about everything I can find on Slate Roof Installation for covering what looks like a 50 square foot out-house.
                            Mike (mfiore) asked me about the twin ridges I have in my roof. Here is a pic of it, I'm pointing at 1 of them. Also, here is a pic of 2 roof trusses and what I've been told is the better way to make them: The cross beam should be as whole as possible, don't cut the sides and create dog-ears of flaps (if possible) so you keep the framing member. The cross beam can be screwed on the outside of the truss (upper example in the pic) since you don't see it on the roof and the outer truss can be cut into the frame (lower example).
                            Thanks again, Dino
                            My Oven Thread
                              Dino, have you picked out your lights yet?
                              Bill
                                Ya Bill, I ordered 2 lights at $34.50 each from
                                [url=http://www.homecenter.com
                                Type in "recessed lights" in the search in it's on the 2nd or 3rd page #9409-12. 2 others look similar but are not weather proof.
                                That should take you right to the fixture. Its listed for wet location, low voltage so I just used "malibu" cable I had laying around. They are still being shipped to me so when I get them I'll let you know how good this company is. I'm hoping it works out like other super small recessed lights I've installed my house, just drill a little hole, connect the LV cable and it clips into the raw drywall or plaster. Take care, Dino
                                My Oven Thread
