Ellie's WFO as it it built
  • Ellie
    • Dec 2008
    • 94
    #61
    Re: Ellie's WFO as it it built
    Now, I don't remember. I do know that in reading the plans, we did not need to add any insulation to the dome once it had the refractory mortar on it. If that is the case, then it may seem that adding a layer of insulation and more mortar should not hurt it. Now, of course, I have to start worrying, which I do well!!
    Ellie
    • Les
      • Sep 2005
      • 2945
      #62
      Ellie,
      I believe you are mistaken - you DO need to add insulation to the dome. Am I misunderstanding what you mean?
      Les...
      • MAVANO
        • Jul 2008
        • 102
        #63
        best thing is to add 1-2 inch ceramic blanket than wire and mortar I dont think that regular house insul. is for high heat
        • Ellie
          • Dec 2008
          • 94
          #64
          Well, I better go back to the drawing board. I will confer with Dale and see what we can do. He has already put the mortar on it.
          I guess the only recourse is to leave it sandwiched in between the layers of cement/mortar. Then, find the blanket (that has been the issue) and put it over this last layer and add another layer of mortar.
          I mean if it burns, it is not going anywhere.
          Ellie
          • Ellie
            • Dec 2008
            • 94
            #65
            Hooray!! I found the blankets. Actually, they are pretty expensive and don't come in rolls like the ones I saw on the internet.
            These are 24x32 or something like that. They are one inch. They had that and 1/2 inch ones. I got two and that will have to do at these prices.
            How do you secure them to the dome?
            Thanks,
            Ellie
            • tdibratt
              • 112
              #66
              The ceramic blankets are typically secured similar to the way you did the first layer. Using chicken wire over top. I used bricks around the perimiter and on top until I started to coat it with the vermicrete mixture. Once the vermicrete went on I removed the bricks that were just there to keep things together until the vermicrete went on.
              I am not sure about leaving the first layer on, you may want to fire it up gradually. You do not want to drive it hard and have everything crack on you. So fire it up slowly over the period of a week or so getting it hotter each day. And see if that insulation does not produce any ill side effects.
              If you go ahead with the blankets and find that it fails, I am not sure what it might do.
              Regards..
              Check out my build at:
              http://www.fornobravo.com/forum/f8/t...uild-4678.html
              • Ellie
                • Dec 2008
                • 94
                #67
                Well, I found in the plans on page 38 "You do not need to add thermal mass to your oven at this point, because the mass of he bricks adn the mortar you have used to hold it together are more than sufficient for backyard pizza baking or even restarurant pizza baking for that matter..."
                This is after completing the dome.
                We are adding brick to the outside of the dome as well, so I think we have enough insulation at this point. I am talking with Dale this morning to make the decision whether to put the thermal blanket over the thing before the bricks or not...
                Ellie
                • Modthyrth
                  • Mar 2008
                  • 359
                  #68
                  Thermal mass is different than insulation. Thermal mass is the material--firebrick and refractory mortar and such--that soaks up and radiates the heat. The insulation is the stuff outside the thermal mass that keeps the heat where you want it (in the oven) instead of leaking out. The plans call for ceramic blanket or vermiculite or perlite mixture, but I'm certainly very curious to know how the house insulation works! Have you fired up the oven yet for curing to see how the insulation reacts?
                  I'm not sure if we're dealing with a simple typo/word-mixup here (in post #61) or real confusion that's going to affect how your oven performs. Exterior cladding, outside of the insulation layer, is not considered adding to the thermal mass of the oven. You're certainly right that you don't need any more thermal mass. We're just a wee bit worried about the unconventional insulation.
                  Nikki
                  • egalecki
                    • Mar 2008
                    • 1049
                    #69
                    I may be wrong, but it seems as though you have thermal mass and insulation mixed up a bit. Thermal mass is what you are heating up- the part that does the actual cooking later. The insulation is what you need to keep the thermal mass hot longer, so you can use less fuel and maximize the potential for retained heat cooking. Bricks and mortar don't insulate (unless the bricks are a special insulating brick), and, in fact, will make it take longer to heat up the oven, since they add mass.
                    If you have the proper insulation (vermiculite, vermiculite concrete or insulating blanket) between the layers of firebrick and the outer layer of brick, then you've isolated the thermal mass of the firebrick from the outer layer. No problem there. We just aren't sure that your batt insulation with the paper off is going to adequately do that job. It'll still cook pizza, but it'll take you longer to heat it up and it will cool off quickly and you won't get the ability to use the oven for several days on one firing. That's all.
                    Please add the insulation if it's at all possible. You'll be happier in the long run.
                    Forgive me if I'm wrong about the confusion. It just read that way to me.
                    Elizabeth
                    • egalecki
                      • Mar 2008
                      • 1049
                      #70
                      Nikki and I cross posted!
                      Elizabeth
                      • Ellie
                        • Dec 2008
                        • 94
                        #71
                        Nope you are right, I am confusing the two. Dale and I looked at the plans again... my fault for not researching more thoroughly here. He is such a good guy. He thinks it is ok the way it is, but says it is up to me. For my comfort level, we agreed to put the blanket on it and one coat of mortar over that..... the stuff I found is not going to work, it is too small. We are having a heck of a time finding the right stuff to do it with.
                        You are all so kind. Even when I am not understanding things, and am dead wrong on some, you point it out ever so gently. I appreciate that.
                        Question: if we cannot find the ceramic blanket, can we just use the vermiculite mixture to go over it? Would this work as enough insulation?
                        Ellie
                        • Jed
                          • Apr 2008
                          • 428
                          #72
                          Hi Ellie,
                          At the risk of confusing more than helping, I'll weigh in here and add an opinion or two...
                          That you have installed a bit of mortar on the outside of the fire brick is just fine. It will add a bit of 'thermal mass' to your oven, but you will get used to how your oven works, and it will all be fine... no worries.
                          On the insulation, there are a couple of questions...
                          When you use household fiberglass insulation next to your fire brick, you are in 'unknown territory' for my experience. I know that fiberglass works at 'household' temperatures. I don't have experience with this product next to a fire brick that will be hot (I don't know how hot - maybe 6 or 700 degrees?) When I read the 'spec sheet' from a fiberglass insulation manufacturer, I think it says you will be just fine (PINK FIBERGLAS? Insulation R-15 then go to the link titled "product data sheet" ). On the second page, middle of the page is says you can use this product next to masonry, but not next to metal flue's and such... It says this product doesn't burn (it is glass).
                          The option to using household fiberglass insulation is to use an insulation product that is designed for masonry projects. The stuff you just bought.. We know it will work well, and at the end of the day, oven performance is directly effected by good insulation. More insulation is just about always better.
                          All insulation works by creating 'dead air space'. When you install the next layer of masonry over the insulation, the insulation will work best if it doesn't get smashed - squished - soaked with water - compressed - etc.
                          And since the job of the insulation is to create a thermal barrier, you can use masonry on the outside of the insulation without effecting the function of the oven. Use any stone or brick you want to make the oven look really good. Your insulation will keep the heat in the oven, and not leaking out through the walls...
                          So I hope this helps...
                          You two are doing great! Don't let these details get in the way of having fun building this oven! You are most of the way through the building process and all to soon you will be finished with this part of the project and on to learning how to cook with the new WFO.
                          JED
                          • Ellie
                            • Dec 2008
                            • 94
                            #73
                            Jed, that really sums it up nicely along with the others.
                            Do you all know.... can we use the vermiculite/cement mixture over the top of the dome if we cannot find the ceramic blanket?
                            Thanks,
                            Ellie
                            • Modthyrth
                              • Mar 2008
                              • 359
                              #74
                              You can definitely use just a vermiculite or perlite and cement mixture as your only insulation. Plenty of people have done that with great success. I think there are guidelines in the plans as to how thickly it needs to be put on to be properly effective.
                              Nikki
                              • Ellie
                                • Dec 2008
                                • 94
                                #75
                                Great! Thanks, I believe that this will be the way for us to go. We simply cannot find the ceramic blanket here, other than the small pieces I can get and they are $35.00 each. We would need several of these to cover the dome and that is way too much money!!
                                I am so relieved and excited to move on now. Wait until you see the front of the oven and what Dale has done there. He got a little artistic and I love it! I will try to take pictures tonight and post.
                                Ellie
