Re: OctoForno
Interestingly, I had this same concern and abandoned my original plan which included the conventional 5.5" soldier course in the dome and a four-deep vertical-walled entryway. This was based on my readings of Forces Acting in Arches and Vaults, which can be found here:
Auroville Earth Institute
However, after my I completed the masonry portion of my oven, I totally agree with Stonecutter, and that a number of these forces are not significant, at least in the scale that our ovens occupy.
With zero prior building experience, I tried to apply to my build every sound principle I could learn, including lines of thrust, not only in the dome, but also in the archway design which is also semi-circular. Because of the heatbreak, my entryway is essentially it's own separate, smaller vault, which has no additional buttressing to support the weight of its flue (unlike the oven arch that is tied into the oven itself).
I applaud your interest in applying sound principles in overcoming gravity and predictably, heat transfer. I too, was critical of every element (I could think of) I observed in previous FB builds and tried to envision a better approach. I think this kind of scrutiny is what makes for the evolution of WFO's and with the collective's contributions, result in viable improvements.
John, I have been wondering about an issue I see with some of the builds on here. Being a mason by trade, what I see that concerns me is the construction of the entries on some builds. I believe the stronger entry is the type you built, where the arch starts right at the floor. I see some where a short height side wall is built then a shallow arch connects the two short height walls. My thinking is that this could over time collapse. These brick side walls are not tied back into the dome structure itself
