Re: OctoForno
Hi
beautiful brick work!
HOW IS THE SOAPSTONE WORKING OUT?
I have SS slab I plan to use and have been told "it gets too hot" while at the same time "it takes too much heat " and you can't cook correctly -what ever that means.
So im confused - should I add more mass under my SS or reduce it? Should I insulate more under it or reduce it?
you seem to have the quintessential build here. I think you may be crazy but at least you can eat well!
thanks for all your info - priceless.
kinda fun to read a small journal of your life in this build forum.
Hi
