Re: new build in werribee
Hi Dennis the floor is layed on 6 mm sand/fireclay decided it didn't need to be wet [so a dry mix] and was easier to lay the tiles due to the tiles being used and the horror stories I had read on calsil absorption rate and since discovered.
I am mortaring the outside course in to bring the height to the same level as the Hearth, hence the comments about the calsil and it being a sponge.
Arrrh it was you Dave, that mentioned that in previous posts, I just couldn't find it, thx. Will try it today 'any brand in particular'
just like greasing a cake tin before putting the mix in.
Thx Allan I have noticed that and will adjust it today. In the interim I have been using cardboard to level it whilst I check everything.
As for the soaking of bricks.... if they are not soaked the calsil and firebrick was simply sucking ALL moisture from the mix, instantly, making it completely unworkable. I mean completely unworkable. The calsil [the fire bricks had been soaked] acted like a bloody sponge. That's why I threw a scrap piece into water it was completely saturated in less than, 5-10 seconds.
Also I am NOT a bricklayer with 30 years experience and I need a little more time to get it all aligned. Especially when moisture is sponged out in less than 3 seconds no matter how wet the mix was.
David [and Wayne] as usual all information ready at hand, thankyou I have actually read that link in my research, and it made for interesting reading.
Thanks guys all comments they are really appreciated.
Originally posted by deejayoh
View Post
View Post
View Post
Originally posted by david s
View Post
