new build in werribee
  • Bacterium
    • Apr 2007
    • 560
    #316
    Re: new build in werribee
    Colin,
    When I get home before dark one night I"ll take and then post pics of mine on my build.
    Basically there was little gap left under eave and top of arch (700mm) I just took the flue box all the way down.....so unfortunately no exposed stainless just black outer wall.
    Dektites are a great sealand create a neat finish around roof too
    Damon
    Build #1
    Build #2 (Current)
    • oasiscdm
      • Jan 2012
      • 1239
      #317
      Hi
      Damon more photos are always usful.
      Russell i'm getting a quote from the UK for Selkirk flue. Guessing will be out of price range but I do not believe I cannot find a similar flue over here.
      I tried the US Selkirk company but they refer back to the UK.
      here is my guess of price 380pound + around 100 pound delivery so around 500 pound so around $704 aud. Considering a normal retail Aussie double skinned flue no insulation or twist lock or 316 stainless is about $300 AUD
      Way too pricey or as you said spendy.
      Cheers Colin
      Oven 1 Completed
      Oven 1 and surrounds
      • oasiscdm
        • Jan 2012
        • 1239
        #318
        Hi all
        Well after 3 weeks where I couldn't get to, getting back to, finishing the 3rd course I completed it today. So far I am maintaining the small joints I have for the most part but have made a couple of small errors [like answering the phone while trying to lay a brick and then it set not quite in the right place but left it there might run the angle grinder over it]. Also joints are bigger in a couple of places, but am mainly trying to get that brick to brick internal finish.
        Tomorrow weather permitting 4th course, hopefully start of 5th course also. Getting the hang of the mortar now, works with a, not quite stiff whipped cream consistency, allowing the brick to be set and pushed in place. I dunk the bricks in a bucket of water first, and spray where I am laying twice prior to setting brick. Seems to be working well now.
        I guess gravity will begin to take effect soon with the arch bricks.
        Cheers Colin
        Oven 1 Completed
          • 5260
          #319
          Very nice work!
          • oasiscdm
            • Jan 2012
            • 1239
            #320
            well I got some more done today not as much as I wanted. I was not happy with some of the work I had done so took an angle to the inside. Quite effective actually, was able to get rid of the overlap [when brick placed over previous bond] quite easily. I also needed to get my circle back seemed to be out from one side to the other by about 5-10mm. Hence the angle grinder. Using the IT on this course to achieve that.
            Am not looking forward to going higher as maintaining this internal zero mortar obsession might prove very difficult. Again lots of photos that I will replace with daylight shots when I get chance.
            Cheers Colin
            Oven 1 Completed
              • 2848
              #321
              Gudday
              That's the thing about getting hooked on this oven building thing.... You have your own time frame . Unlike any other thing in the house .. You don't have time pressures like a bathroom refit or a kitchen , just take your own time.
              It's not like its going anywear it will just sit and wait for the time and energy.... It definitly not like the lawn mowing or car washing ... A have too task ...it just sits and waits for you
              • oasiscdm
                • Jan 2012
                • 1239
                #322
                Hi
                Well I got course 4 finished [well nearly one brick either side of arch left] spent the day getting it back to round [yep cocked up not sure how]. I have a 8-10mm rebate on one side and overhang on the other course not aligning to the one below, on both sides of the arch, going back about 300-400mm from the arch.
                It is back to round now, I will lay the next course, then take to the inside with an angle grinder and smooth things over removing the problem.
                I have decided to do this to get rid of the T shape as I tried last week and it is easier than how Gianni described in his post [doing it on the brick saw]. Flap disks [metal]worked ok and less harsh than a stone cup wheel. Got a respirator to do this task.
                Will post some photo's another time, as I've got new phone and need to work out how it works.
                Cannot wait for Queens Birthday weekend think I'll take day off, pray for great weather and spend 4 days working on it. Hopefully getting past the arch dome transition.
                Cheers Colin
                Oven 1 Completed
                • brickie in oz
                  • 3445
                  #323
                  Didnt you see it when you were laying them?
                  • oasiscdm
                    • Jan 2012
                    • 1239
                    #324
                    HI Allan
                    Not until the 3rd course, Since I started at the back I only noticed as I got towards the arch. Decided to correct it on the forth course.
                    I think the problem is that the IT needs to be adjusted each course to match the dome template and I think I must have knocked it.
                    I'm not overly concerned as I can reshape inside as I described above, outside I don't care much about as obviously it gets covered and covered and coverered. I was always going to grind the T's inside the oven anyway, its just now it needs to be a little more severe.
                    Added some photos from weekend efforts.
                    Cheers Colin
                    Oven 1 Completed
                    • oasiscdm
                      • Jan 2012
                      • 1239
                      #325
                      and a couple more
                      Cheers Colin
                      Oven 1 Completed
                        • 5260
                        #326
                        Colin,
                        Brick work looks nice and tight. I too had to adjust the IT length as well as grind some overlap off as I tied into the arch. Make your adjustments over a couple courses so it is spread out. You will be clearing the arch soon. Good work.
                        • oasiscdm
                          • Jan 2012
                          • 1239
                          #327
                          Hi Russell
                          What did you use on your grinder.
                          Cheers Colin
                          Oven 1 Completed
                            • 5260
                            #328
                            I have a angle grinder with a 5/8" threaded arbor and I used a diamond cupped wheel which are about $20 USD.
                            • oasiscdm
                              • Jan 2012
                              • 1239
                              #329
                              Hey Russell same as mine exactly.
                              Cheers Colin
                              Oven 1 Completed
                              • oasiscdm
                                • Jan 2012
                                • 1239
                                #330
                                Hey course 5 finished.
                                After a trip to dentist to get tooth fixed decided to complete the course and get ready for next course well nearly got there but ran out of day light. Was hoping to get 3 bricks in place on next course give me head start for weekend.
                                Here's some photos. Think I may have beginning of dreaded droop. But could be optical illusion too. so took some photos for a more objective look. Only problem it was dark. Will put a level across it in daylight and see.
                                I intend to mark the centre of each brick with the IT/String and take my time [I am going to attach a chalk line to my IT] as rushing caused some minor and a couple of more serious alignment issues but have managed to maintain tight internal joints. I am back to round now.
                                Hey Allan [Brickie in oz] if you see this, how do you lay the last brick on the arch?, 2mm gaps I find the mortar is just pushed out. Is there a technique? I found around the dome the mortar gets pushed out. Must be missing something, have cut the back of the brick around the dome to allow mortar. But the arch to me is a challenge getting mortar in those 2-3mm gaps.
                                Cheers Colin
                                Oven 1 Completed
