new build in werribee
  • oasiscdm
    • Jan 2012
    • 1239
    #481
    Re: new build in werribee
    Originally posted by benguilford
    Looking great Colin!
    Thanks Ben, I tell you though I am bloody sore. Getting that brick to brick fit is Damn hard work fine tuning each brick. Up down backwards and forwards.
    I hope the expectant father appreciates what I've done with his bricks.
    Brickie I hope to dock next weekend.
    Cheers Colin
    Oven 1 Completed
    Oven 1 and surrounds
    • Sharkey
      • May 2010
      • 150
      #482
      That's a good looking dome. Great to see it all working out as planned.
      Sharkey.
      • oasiscdm
        • Jan 2012
        • 1239
        #483
        Thanks Sharkey
        and thanks for your assistance throughout the build. Esp. around that annoying triangle.
        __________________________________________________ _______________________________________________
        Hey I had a brain fart today and am thinking of polishing the inside of the dome and the floor or maybe just the floor. If I can work out how I might get in the dome to do it, stop safety glasses from fogging up. But then again .............
        Not sure how or what tools to use though. Floor not an issue I have an orbital sander for floor, dome a bit harder I believe I could only use a 3" sander, grinder not sure. Any ideas of how I might achieve this and what to use?.
        and by all means please try and talk me out of it
        Cheers Colin
        Oven 1 Completed
        • mrchipster
          • Apr 2010
          • 1502
          #484
          That is an oven worthy of high praise, beautiful brick work, I cannot wait to see what you do with the outside.
          Chip
          • oasiscdm
            • Jan 2012
            • 1239
            #485
            Thanks Chip for the vote of confidence. Its taken a while but must still be patient.
            Sorry to disappoint but it wont be as elaborate as some. I viewed Gulf's build the other day and his is finish is amazing. Yours is amazing however my plan Chip is to stick with the igloo look. Not the dog house. Having some challenges figuring out the BBQ position with WFO being so close to the Corner but will worry about that later.
            I am finishing the outer decorative arch with the same brick as my home, maybe with a larger central brick which I will Coat with a rust look finish that I have used on cement pots.
            I am following a commercial oven builder's advice and using shiralite then the blanket, render and then finishing with a granite look finish coat.
            Cheers Colin
            Oven 1 Completed
              • 5260
              #486
              Colin,
              IMHO, leave the inside of dome as is, when you fire it will get sooted, then clear, get sooted, etc. You could smooth off any high edges on the "floor" that might catch a peel though. Nice build, excellent taper arch.
              • oasiscdm
                • Jan 2012
                • 1239
                #487
                Colin,
                Thanks Russell
                Thanks for the compliments much appreciated.
                I do have a tip I got from Doug to break the soot clear soot cycle. Apparently Doug's oven is always clean. How he does it goes like this. Heat oven to pizza temp, cook pizza, before closing down wfo, after pizza cook, re heat oven to pizza temp, remove fire when dome is clear, seal oven with door, sit around fire with a nice wine [I added this bit ]. Oven stays clean you can then cook over next however many days.
                Cheers Colin
                Oven 1 Completed
                • deejayoh
                  • Jul 2010
                  • 1893
                  #488
                  I agree with Russell on there not being any need to grind the inside of your oven. Spend as much time as you like, but I can just about guarantee you won't be looking at it once it's complete.
                  As to Doug's "tip" - that's pretty much just the way it works... The oven gets sooted every time you light a fire, clears when you get it hot enough, and stays clean until you light another fire. Wash, rinse, repeat
                  • brickie in oz
                    • 3445
                    #489
                    I have 3 questions.
                    Why, why and why?
                    • oasiscdm
                      • Jan 2012
                      • 1239
                      #490
                      I have 3 questions.
                      Why, why and why?
                      Hi Allan
                      too answer each question.
                      Just a thought, just a thought, just a thought
                      Seriously
                      I guess no body else has...because I can.. I have spent a lot of time Admiring Gianni's soap stone and it just looks very clean. So if I polished the floor it would be much easier to clean. As for the dome hmmmmm it would be
                      Cheers Colin
                      Oven 1 Completed
                      • brickie in oz
                        • 3445
                        #491
                        The fire cleans the floor.
                        • CrocAu
                          • Apr 2013
                          • 164
                          #492
                          Floor will expand at different rate so anything you make smooth today might not be smooth after few big fires
                          • deejayoh
                            • Jul 2010
                            • 1893
                            #493
                            Its not a beauty contest
                            • CrocAu
                              • Apr 2013
                              • 164
                              #494
                              oh but it is
                              • Bec1208
                                • Nov 2012
                                • 416
                                #495
                                At least not the way I did mine. Still this build is a thing of beauty. Bruce
                                Link to my build here:
                                http://www.fornobravo.com/forum/f6/3...lly-19181.html
                                Selected pictures of the build.
                                https://picasaweb.google.com/1168565...g&noredirect=1
                                sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
