new build in werribee
    • 5260
    #631
    Re: new build in werribee
    Brick work for you vent arch looks nice, like the curved inner vent area. Nice score on the SS cutoffs. Looks like you have plenty for tools and door. I guess you can either tig weld or know someone who can.
    • oasiscdm
      • Jan 2012
      • 1239
      #632
      Thanks Russell
      Yeah a friend of mine does my welding for me, he happens to be a fitter and turner engineer fellow that runs his own business repairing hydraulics. he made the Bricksaw jig for me and my concrete form for the base of the supporting structure for the oven. I can do most things but was never any good at welding.
      Thanks for the suggestions re PM i sent.
      Cheers Colin
      Oven 1 Completed
      Oven 1 and surrounds
      • oasiscdm
        • Jan 2012
        • 1239
        #633
        Hi
        Got home with some new toys that were delivered [Cobblerdave you know which one it works very well] and a die nut to thread some stainless tube for my home made thermowells. Worked a treat see photo below. I also finished the front Landing Arch and tidied the entry removing the arch form.
        Cheers Colin
        Oven 1 Completed
        • GianniFocaccia
          • Jun 2009
          • 1645
          #634
          Very nice indeed, Colin. Your entryway is beautiful.
          John
          • Greenman
            • Feb 2013
            • 1123
            #635
            Looks good Colin. Clean and neat.
            Cheers ......... Steve
            • oasiscdm
              • Jan 2012
              • 1239
              #636
              Originally posted by GianniFocaccia
              Very nice indeed, Colin. Your entryway is beautiful. John
              Thanks guys - John thanks too you and many others, your lead on the entry way made my path easier. Now for the hard part putting that round peg in a square hole. As you can see by the scribble on the tile that is my square hole. John I have decided to transition the 3" thick tile from square to round through the 3" thickness too allow a seamless transition from the entry gallery following the taper I have their already front and back.
              I will cut the circle out right through using the method you suggested in our discussions about this [I have a 6" Diamond blade now so can get through]. Then use the blade to shape the transition and finally use my granite sanding discs to shape from square to round. So hopefully all done in a single piece.
              Then again .... It might be to hard. but will give it a shot.
              Cheers Colin
              Oven 1 Completed
              • oasiscdm
                • Jan 2012
                • 1239
                #637
                Arrrrgh every time I go too work out on WFO it rains, but why almost most weekends. Then I go to work and its nice and sunny. I thought it was spring/summer.
                Anyhow got the hole in the tile cut in between rain bursts. Thermowells ready. Templates marked out for decorative arch.
                Cheers Colin
                Oven 1 Completed
                • oasiscdm
                  • Jan 2012
                  • 1239
                  #638
                  Hi here was the process I used should anyone else wish to try this.
                  Cut out a square within the circumference of the circle for the flue. I used a 6" diamond cutting wheel on a 5" grinder. BE VERY CAREFULE as the guard needs removing.
                  I then held the grinder on an angle and cut horizontal grooves into the tile from the square into the brick to the marked circle. then knocked this out and tideied up by moving the grinder held flat up and down the edge. I did this until half way throught he tile.
                  I stood it up like in pic 4 and then cut vertical grooves to the line of the circle and then knocked these out with the hammer and then tidied up the circle the came way by running the grinder up and down horizontally to give me the circle I needed.
                  Cheers Colin
                  Oven 1 Completed
                  • oasiscdm
                    • Jan 2012
                    • 1239
                    #639
                    Part 2 of the process.
                    Required making the flue gallery [exit flow] as smooth as possible. I used a die grinder with 40 grit bits to grind the square corners and edges to fit the flue gallery dimensions.
                    Cheers Colin
                    Oven 1 Completed
                    • kbartman
                      • Feb 2013
                      • 572
                      #640
                      Superb work Colin. Look forward to seeing it on the oven.
                      Is your spring/summer considered your rainy season? We are in fall/winter season here, very dry of the time.............. I need your motivation then maybe I could get my stucco job finished......."Just Do It"...... Of course our rainy is still many months away.................
                      Respectfully,
                      KB
                      My build
                      • stonecutter
                        • Jun 2007
                        • 2003
                        #641
                        Originally posted by oasiscdm
                        BE VERY CAREFULE as the guard needs removing...
                        Is the guard that half-circle metal thingy? When I buy grinders, that goes into the garbage with the handle and case.
                        Nice work on the throat Colin...very clean.
                        Old World Stone & Garden
                        John Ruskin
                        • oasiscdm
                          • Jan 2012
                          • 1239
                          #642
                          Is your spring/summer considered your rainy season? We are in fall/winter season here, very dry of the time.............. I need your motivation then maybe I could get my stucco job finished......."Just Do It"...... Of course our rainy is stay many months away.................
                          Well not normally, more windy than rainy. Normal weather is dry and warm but lately very winterish.
                          Am hoping to get it on the oven tomorrow. My motivation is called Xmas. I need it operational by then. Don't care if the render [stucco] is not on it. Just insulated and cured will do me. then finish on the other side of xmas.
                          Yes stonecutter, it is that half circle thingy. I keep the guards for cut off wheels, mainly as it stops crap being shot into your face.
                          Thanks for the compliments, took most of the day though to get it right and sized to the gallery.
                          Guess I succeeded in putting round peg in a square hole.
                          Cheers Colin
                          Oven 1 Completed
                          • stonecutter
                            • Jun 2007
                            • 2003
                            #643
                            I was attempting humor there Colin. ....but I really do chuck them with the case and handle every time. I won't recommend operating without a guard to others, but I never use them myself. They limit the use of the grinder too much for my liking. I do wear safety glasses though...I don't use the safety squint method anymore.
                            John Ruskin
                              • 5260
                              #644
                              Colin,
                              Wow, round hole, square peg. Nice work, just like everything else on your build. Suggestion, make sure the anchor plate is completely level, test fit the chimney piping and check for plump. I did not and my chimney is slightly out of plumb and no way to adjust now.
                              • brickie in oz
                                • 3445
                                #645
                                Nice job on the hole, only problem is it will probably go click and crack when it gets hot as youve taken all the strength out of it.
