new build in werribee
  • oasiscdm
    • Jan 2012
    • 1239
    #661
    Re: new build in werribee
    So I have now worked towards completion.
    i'm just going to post a mess load of progress photo's in some order first the flue gallery completion.
    Cheers Colin
    Oven 1 Completed
    Oven 1 and surrounds
    • oasiscdm
      • Jan 2012
      • 1239
      #662
      Got a start on the decorative arch. I wont progress much before Xmas on this unless I get it insulated quickly.
      You can also notice the thermocouples I made poking out. My idea is that I will cap them and use as I see fit. Might make them permanent or not. Will decide later but will only use 5 in total should I go that route.
      Cheers Colin
      Oven 1 Completed
      • oasiscdm
        • Jan 2012
        • 1239
        #663
        Then the brick cap around the flue. Hey Russell does it look familiar. I used arch bricks so water can run away from the flue. Will seal later.
        Cheers Colin
        Oven 1 Completed
        • oasiscdm
          • Jan 2012
          • 1239
          #664
          And a few more
          Cheers Colin
          Oven 1 Completed
          • oasiscdm
            • Jan 2012
            • 1239
            #665
            And what everyone likes to see FIRE. and it felt good...and even draws ok.
            Last photo is the nice and tidy and clean dome no longer tidy and clean.
            Was quite surprised how hot it got up top. Will get a layer of insulation [shiralite] on, on the weekend and then begin the cure while I get the blanket on.
            And thank you to all those who assisted as I couldn't have achieved what I have without all the help you guys have provided to me via posts, PM's, emails and by phone.
            Anyway pizza not far away.
            Cheers Colin
            Oven 1 Completed
            • kbartman
              • Feb 2013
              • 572
              #666
              Congrats on the first fire, looks like everything is coming along nicely. I can smell the pizza baking already can't wait to see the pics.
              Respectfully,
              KB
              My build
                • 2848
                #667
                Gudday
                Unless you get the insulation done? It will able to be used without it. Never really made up my mind completely on which way to go on when to cure. I lean towards curing the dome shell before insulating. My gut feeling is there is to much water trapped by to many layers and a lot of a lot of ovens and they crack due to steam.
                My own experience was the wood form was burnt out and I used the oven before I used dry insulated and rendered. Min moisture and only a couple of hairline cracks in the entrance due to having steel supports.
                Using pearlcrete as a layer above the dry insulation I don't think myself is really required and only adds extra moisture and complexity to the build. You can render over dry insulation and get a good shape. If fact pearlcrete is a sh@t to work with and the water pours out of the stuff into your dry insulation which can't be good. Render is much easier to work into shape than pearlcrete.
                • BOOMERS WFO
                  • Apr 2012
                  • 113
                  #668
                  I agree with Dave. I took the advice during the build to cure while working finishing oven, all the moisture was gone by the time I insulated.
                  I had cooked quite a few pizza's whilst I was waiting to finish.
                  In fact, the insulation was on for some time before final vermiculite and render layers applied (covered with a tarp).
                  Over 12 months later, I only have two small cracks in outer render, and these are near the vent where I know the blanket was not applied as well as the rest of the dome.
                  Craig
                  "All I ask is the chance to prove that money can't make me happy"
                  Spike Milligan
                  "It is only impossible if you stop and think about it"
                  The Pirate Captain
                  • oasiscdm
                    • Jan 2012
                    • 1239
                    #669
                    Craig
                    Gudday
                    thanks Dave and Craig
                    I understand both your points of view and have agonized over this one, especially considering that everyone has done the reverse of what I am doing.
                    However, after much consideration and views from 3 commercial oven builders I have decided to use Shiralite around the Dome to insulate and lock the bricks in place. It is used in Commercial oven builds in this order and suggested to me by someone that has been in the oven building business for 30 years. I then researched it too death.
                    Once this is layed over the Dome I will begin a slow and steady oven cure.
                    Once the Shiralite has dried [very easy to tell] I will then begin to apply the Blanket. Now I know various builders out there say always use the blanket first as it is a better insulator but insulation is insulation. My view after research is that blanket is flexible so if using 75 - 100mm of blanket then vermicrete, then Render. Then you have a soft layer over the oven. Its just a view I have that differs from the norm.
                    I do intend putting in a vent at the top of the Dome like yours Dave which by the way I must go and get before the weekend.
                    I built a Utahbeehiver special today.
                    Cheers Colin
                    Oven 1 Completed
                      • 5260
                      #670
                      Colin,
                      Lots of ways to skin the cat, sometimes ya just got to do what works for you.
                        • 2848
                        #671
                        Gudday Colin
                        Yes what you doing is sensible, you will be drying the oven out at the shiralite stage which is great as you will not arrive at the end with a huge mass of wet oven.
                        regards dave
                        • oasiscdm
                          • Jan 2012
                          • 1239
                          #672
                          What's interesting with shiralite is you know it's dry by the color it turns. Acquired a burner like Liteceeper used. Will double as a paella burner moving forward. Of course I can use oven too.
                          Cheers Colin
                          Oven 1 Completed
                          • Liteceeper
                            • Jul 2013
                            • 90
                            #673
                            Liteceeper 3 more question.
                            Do you have a close up of how you fastened the blanket in place?.
                            Also did you lay the render in one day?
                            and how many bags and what brand render did you use?
                            Love the symmetry of those render application shots. Your application technique is simple and effective with the flexible pipe.
                            Hi Colin
                            Apologies for the slow reply, been cookin
                            The render was laid one strip per day, I initially laid a 3" (75mm) strip using plastic garden edging set out from calsil with 2" (50mm) timber blocks and held in place with bricks.
                            Then next day rendered between this and the 2" (50mm) corrugated conduit, in hind-sight I would have made the first strip slightly smaller about 6" 180mm.
                            Let set overnight, removed conduit next day and set higher after trimming for diameter reducing. Repeat until at top where I laid strips across top to continue gauge as diameter to small for a circle of conduit.
                            The render was 5:1 Exfoliators Litefill Premium Perlite and Brightonlite HE cement. I used 3.5 8kg bags of perlite and 4 20kg cement.
                            Blanket held by wires ran across dome to long screws anchored in calsil board with about 6" of tail on each end of wire. I had a screw in top centre of dome which I wrapped wire around and continued to screw on opposite side when all wires in place I removed screw and tie all wires together with small piece of wire. This allowed wires to be removed from screws as blanket was wrapped around dome and wires passed over blanket. The blanket had wedges cut with large shears to allow for neat fit.
                            Liteceeper
                            My Build - http://www.fornobravo.com/forum/f51/...ide-19729.html
                            My Door - http://www.fornobravo.com/forum/9/sh...tml#post170496
                            "Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
                            • oasiscdm
                              • Jan 2012
                              • 1239
                              #674
                              Thanks Liteceeper.
                              One more so your render is perlite and cement! Is this the top coat or will you be using a cement solid render on top of that?
                              Love your technique with the blanket.
                              Cheers Colin
                              Oven 1 Completed
                              • Liteceeper
                                • Jul 2013
                                • 90
                                #675
                                Thanks Liteceeper.
                                No, top coat will be DryPak Render Coat same as patio walls approx 5-8mm thick.
                                Not sure what I will do then paint, tile, stick on brick ends.
                                Liteceeper
