new build in werribee
  • oasiscdm
    • Jan 2012
    • 1239
    #811
    Re: new build in werribee
    Ok thanks guys. Lit fire at 12pm cleared at 1.30pm top of dome 650c half way up wall 520c hearth 415c and rising.
    Smaller wood, more of it oven even cleared consistently.
    This was taken the other night Son bought back a chefs hat and apron from Paris. Look like a dork and I don't think the color is appropriate.
    Cheers Colin
    Oven 1 Completed
    Oven 1 and surrounds
    • Greenman
      • Feb 2013
      • 1123
      #812
      Good outcome Colin. If looking like a dork was an issue then half of the population is in trouble, including me.
      That is a problem for others!
      Cheers ......... Steve
      • oasiscdm
        • Jan 2012
        • 1239
        #813
        Now. That is interesting, I am a mental health counselor/coach. And to be honest I don't care but can take the piss out off myself. Nice one Steve
        Cheers Colin
        Oven 1 Completed
          • 5260
          #814
          ooohh lala..........after pizza you can switch to french baguettes!! Oven looks like it is curing well. Nice to see the yin/yang everytime you clear the dome.
          • oasiscdm
            • Jan 2012
            • 1239
            #815
            Yep curing well. No baguettes for Colin have lost 13kg, Still not sure whether to vent top of dome with render layer.
            The beauty of my yin and yang symbol is watching it magically reappear.
            Lost my temp door turned to ash even with the layers of foil. Never mind got a new temp door
            hebel and calsil scraps.
            The real door still in the building.....
            Cheers Colin
            Oven 1 Completed
            • oasiscdm
              • Jan 2012
              • 1239
              #816
              Hi guys and happy New year. Got the temp up last night and as I write this the oven is still maintaining a temp of 325c cooked a few things today but oven is a bit hot. External surface temp of blanket never got above 45c. With inside temps teaching well over 600c in spots.
              I would like to thank all those that have helped me with my build your assistance had been more than invaluable. I would like to especially thank, Doug, John, Dave, David, Russell, Dennis, sharkey, kb,. Thanks to you all for your time observations, skills and knowledge.
              Cheers Colin
              Oven 1 Completed
                • 5260
                #817
                Colin,
                Happy New Years to you too. I am not sure a pizza oven is good for your figure. I am always on a "seefood" diet, I see it I eat it...........
                • oasiscdm
                  • Jan 2012
                  • 1239
                  #818
                  Hi Russell
                  Simple solution to the weight issue. I have cooked in the oven everyday since Xmas. All on two firings. Whatever I eat had to fit on a butter plate. Only exception was Xmas day and new years eve. But even then I ate not that much more. Lost 12 kg before xmas and am still around the 11kg loss. So all in all doing ok. Freezer is full though.
                  Tonight I cooked kleftico, now that dish is too die for. Couldn't believe cooking it at 350c for 4 hours, would work when I saw this on tv. It simply melted on your mouth. Was dry in parts next time I will seal the pan more thoroughly and add just a tad more water.
                  Sorry no photos was starving and it smelt like it wanted to be eaten
                  Cheers Colin
                  Oven 1 Completed
                  • kbartman
                    • Feb 2013
                    • 572
                    #819
                    Your build is one of the superb well thought out creations of this forum and deserves a mention as one of the treasure troves after your completion.
                    Thanks for saying thanks, although I feel that there are many more skilled then I and deserve my thanks also. Thanks again.
                    Nice hat and apron. I also received a chefs hat, less the colors from my buddy for Christmas. What's the point if we can't have fun cooking in our WFO with our dorky hats. That what its all about.
                    Respectfully,
                    KB
                    My build
                    • oasiscdm
                      • Jan 2012
                      • 1239
                      #820
                      Thanks for that KB.
                      However like you have found the cooking aspect more fun. Been working on the door of and on. Not worried about render off some yet Planning that for Australias day weekend off off course I'm not cooking
                      door will be fully isolated, SS as I Am adapting dino plans.
                      To hold heat door will be 5" thick. Some say to big but it will be very well balanced. 3 layers of SS, sandwiching 50mm calsil and 75mm hebel. Have come up with a unique design so I can pull it apart and experiment with different types insulation [based on Dino's drawings with some modifications]. Will post photos when it's done.
                      Thanks again KB for compliment.
                      Crack report...
                      So far not cracks any where and have used it everyday since xmas
                      Cheers Colin
                      Oven 1 Completed
                      • kbartman
                        • Feb 2013
                        • 572
                        #821
                        Thanks for that KB.
                        To hold heat door will be 5" thick. Some say to big but it will be very well balanced. 3 layers of SS, 50mm calsil and 75mm hebel. Have come up with a unique design do I can pull it apart and experiment. Will post photos when it s done.
                        Crack report...
                        So far not cracks any where and have used it everyday since Christmas
                        Australias day weekend off off course??????
                        Can't wait to see the photos of your door. I will have to take a look at Dino's, I haven't found a design that suits my fancy yet. Well insulated for me as well. My doors are a long way off, must finish the stucco and counters first. I can get by with my temporary for now.
                        Respectfully,
                        KB
                        My build
                        • oasiscdm
                          • Jan 2012
                          • 1239
                          #822
                          Hi KB
                          Australia day is a public holiday over here so a long weekend. Will do render then.
                          Cheers Colin
                          Oven 1 Completed
                          • oasiscdm
                            • Jan 2012
                            • 1239
                            #823
                            Was looking at Brissie thread and noticed he tried a sour dough pizza [nice one Brissie].
                            Has anyone mastered a wholemeal pizza base and if so what flour was used?
                            I was thinking of using Atta wholemeal flour but am looking for alternatives that others have tried. I actually prefer wholemeal bases but have never actually attempted it. Used to have a local pizza shop that would had these on his menu.
                            Cheers Colin
                            Oven 1 Completed
                            • oasiscdm
                              • Jan 2012
                              • 1239
                              #824
                              Cheers Colin
                              Oven 1 Completed
                              • oasiscdm
                                • Jan 2012
                                • 1239
                                #825
                                The streets flue experiment did not work. Pizza looked great cooked will but was soft and not crispy.. made dough the same way as normal dough that works well.
                                Any ideas?
                                Cheers Colin
                                Oven 1 Completed
