new build in werribee
  • kbartman
    • Feb 2013
    • 572
    #646
    Re: new build in werribee
    Originally posted by oasiscdm
    Well not normally, more windy than rainy. Normal weather is dry and warm but lately very winterish.
    Am hoping to get it on the oven tomorrow. My motivation is called Christmas I need it operational by then. Don't care if the render [stucco] is not on it. Just insulated and cured will do me. then finish on the other side of Christmas.
    Pardon the correction Colin, hope ya don't mind. My holiday motivation has come and gone maybe Christmas. I hope get her tidied up by then.
    Nice job on the hole, only problem is it will probably go click and crack when it gets hot as youve taken all the strength out of it.
    Great job Colin,............................ All ovens crack Brickie, you know that.........where is your optimism?
    Respectfully,
    KB
    My build
    • oasiscdm
      • Jan 2012
      • 1239
      #647
      Well I managed to fight the rain and get most of the gallery done. Was going to call it quits but then decided to lay the anchor plate transition tile.
      The flue and anchor plate are not attached I just sat it in place to determine if the flue was straight.
      Next post is everything cemented in place and Russell I have checked and double checked and hopefully it is level.
      I did have one hiccup I cut the front bricks out for the flue gallery and in rebatting them to hold the gallery bricks in place I removed the wrong side of the brick dammmmmmmnnnnnn .......
      Cheers Colin
      Oven 1 Completed
      Oven 1 and surrounds
      • oasiscdm
        • Jan 2012
        • 1239
        #648
        Part 2 everything cemented in place.
        So all I need to do now, is tidy up the gallery, smooth it out, loose those bits sticking out. Complete the dome plug second piece, drill some holes for the thermowells and then lay some bricks around the anchor plate, then onto the insulation.
        yippee fire not far away.
        Cheers Colin
        Oven 1 Completed
          • 2848
          #649
          ....do you cook?
          Gudday Colin
          I'm sure you have done your " due diligence" but are you sure you are able to get your "beastly" to produce the goods. No matter.
          It's seems to be universal the first pizza is always the best ......
          Myself ..... I'm looking foward to seeing the oven in that Japanese setting.....the internals are smooth and simple(?)... The outer I'm sure you will match there setting
          As always regards
          Dave
          • oasiscdm
            • Jan 2012
            • 1239
            #650
            ....do you cook?
            Gudday Colin
            As always regards
            Dave
            Thanks Dave
            Yep, I do probably 80% of the cooking. . As for the Japanese setting I in a very early post was trying to get the igloo to look like a big granite rock.
            Wont happen until new year now, have lost too many weekends. Will be working on the TDC of the decorative arch once I get the template sorted. but focus is now on getting it working so that First pizza has been washed down with a nice PepperJack Shiraz.
            Cheers Colin
            Oven 1 Completed
            • CrocAu
              • Apr 2013
              • 164
              #651
              ....do you cook?
              made me lol with that line
              sometimes you stop and wonder if some of us just like the idea of new "project" regardless if needed or if it is going to be used more than once a year
              • Greenman
                • Feb 2013
                • 1123
                #652
                Every man needs a shed and a project. The shed is the birthplace of all good things and the projects come to life from there.
                Cheers ......... Steve
                • oasiscdm
                  • Jan 2012
                  • 1239
                  #653
                  Nice one Greenman
                  Always thought the the birthplace was called a "hospital" unless a home birth Hmmmm a shed ........ for me its the contemplation lounge [WC] where all good projects are birthed
                  Cheers Colin
                  Oven 1 Completed
                  • oasiscdm
                    • Jan 2012
                    • 1239
                    #654
                    Well, I've done it finally finished the major construction.
                    Nothing but insulation to do and I can use ir.
                    Decorative arch to do, and render, Can both edit until Xmas New year.
                    Will lifght a very small fire, cure after I get it wrapped up.
                    Cheers Colin
                    Oven 1 Completed
                    • Liteceeper
                      • Jul 2013
                      • 90
                      #655
                      Congratulations Colin
                      Hope to see some fire soon, I fired my build first time on Saturday after curing for about 10 days first 7 with gas burner, will post some photos soon.
                      Got an idea for a gauge when doing the render too. 50mm corrugated conduit held with cable ties to wire frame. Helped do the render freehand.
                      Liteceeper
                      My Build - http://www.fornobravo.com/forum/f51/...ide-19729.html
                      My Door - http://www.fornobravo.com/forum/9/sh...tml#post170496
                      "Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
                        • 2848
                        #656
                        Gudday Liteceeper
                        THAT would have to be the neatest, tidiness piece of ceramic insulation I have seen . Bloody well done
                        • Liteceeper
                          • Jul 2013
                          • 90
                          #657
                          Arr shucks your making me blush, but I am pretty happy with the outcome will post some photos on my build soon, been having fun cooking pizza Saturday and roast Sunday.
                          Don't want to hijack Colin's thread.
                          Liteceeper
                          • oasiscdm
                            • Jan 2012
                            • 1239
                            #658
                            I will get some photos up soon. Got heat stroke from being out in the heat all day.
                            Liteceeper
                            Nice idea with the conduit. Might adapt that when I get to it.
                            I agree with Dave re blanket
                            What size burner did you use, gas bottle or natural gas
                            Cheers Colin
                            Oven 1 Completed
                            • Liteceeper
                              • Jul 2013
                              • 90
                              #659
                              Liteceeper
                              Know what you mean about heat stroke, one day we had 37C next day 20C.
                              With conduit just cut down length as you do layers up dome, then cut into small pieces for top of dome.
                              I used a gas bottle, started one Wednesday after work from 4pm to 10pm with a raw dome and small flame got too about 100C. Continued each night to weekend and then started all day burns with larger flame whilst doing ceramic blanket install. Placed door in oven raised on blocks to allow fire to breathe. Got too 250C continued during week and then a couple of days with fire in the hole. Thursday & Friday temps up to about 350C. Did full fire on Saturday evening to clearing dome after having gas flat out all day Saturday.
                              Liteceeper
                              • oasiscdm
                                • Jan 2012
                                • 1239
                                #660
                                Liteceeper 3 more question.
                                Do you have a close up of how you fastened the blanket in place?.
                                Also did you lay the render in one day?
                                and how many bags and what brand render did you use?
                                Love the symmetry of those render application shots. Your application technique is simple and effective with the flexible pipe.
                                Cheers Colin
                                Oven 1 Completed
