Re: new build in werribee
No,
If as I asume you would be using firebricks for the vent hearth, then you could just use the hebel under the firebricks as the vent arch hearth does not get as hot as the oven hearth.
The reason I would use the board is to make it easier to get the same height as what the oven hearth is.
No,
