Re: new build in werribee
Colin,
Judging from the soot signature in your entryway pics, the configuration of your vent is quite effective. It appears no smoke made it out the door and past 50% of the way to your outer arch before exiting up through the flue. Just like stopwatches in timed swimming events (they don't lie), same goes for telltale smoke stains. I would also attribute this efficiency to your hemispherical arch shape, which appears to contribute to a narrower smoke path than a wider, flatter arch. I'm also curious to see how the soot path changes once you get a full fire going.
KBart is right: The ceiling soot starkly displays the accuracy and symmetry of your beautiful brick cuts. Once it clears, you'll see you can go black and go back!
Nicely done, sir!
Colin,
Nicely done, sir!
