new build in werribee
  • Re: new build in werribee
    One of these weekends I will finish the oven. Another weekend lost having to do other things. arrrgh.
    Still To do
    Electrical work
    Ceramic rope in gap at front between entry arch and inner landing arch
    Decorative arch
    My special top dead Centre piece for decorative arch
    Finish render
    Seal
    Render base
    Make 3 doors insulating door, blast door / weather door and hi temp glass door
    Tool draw
    Reseal deck
    Install thermocouple reader install 6 thermoco?ples
    Then finish around the alfresco area
    Cheers Colin
    Oven 1 Completed
    Oven 1 and surrounds
      Still To do
      Electrical work
      Decorative arch
      Finish render
      Seal
      Render base
      Tool draw
      Reseal deck
      I feeling your pain .....My list is just as long.......The list never seems to end, and the weekends fly by.................One day at a time, Right?
      Respectfully,
      KB
      My build
        Be over the moon if I got just one day., but I hear you.
        Cheers Colin
        Oven 1 Completed
          Hi all has been a while
          Nothing done further on build but this weekend have 4 days. I have had all the electrical work done, deck resurfaced and partner and I bought a new house in January. Found a product that will assist me building shoji screens.
          Now you guys need to knock some sense into me , I TODAY bought 48% alumina arch 75 59 firebricks about 200 for $300 for [you guessed it] to build oven at new place.
          Guess I should finish this one first but THAT WAS REALLY CHEAP
          At least I know how now. If you want some cheap bricks and live in Melbourne then PM me and I will tell you where to go.
          So to speak
          Cheers Colin
          Oven 1 Completed
            Never let a good deal go by. I have enough in my shed to build another dome from when I found them at the right price when building my first.
            I do believe that finishing one to find out what you would do differently would be a good thing to do!
            Cheers ......... Steve
              hmmmmm what would I do differently ........ bigger hearth base surface would be it. Similar too Litekeeper
              Cheers Colin
              Oven 1 Completed
                I also see that gradii 400c restaurant won margarita pizza world championship.
                Might go and check it out....
                Cheers Colin
                Oven 1 Completed
                  Hi Steve
                  I just happened to drop in on the guy that supplied me a lot of materials. He had a number of firebricks he obtained from a business that closed all new. He had some strange fire bricks all 47%. Including 2000 that tapered like wedges, and some other that were angled on one side only [key bricks]. He wanted a price then gave me a much better deal worked out to around 200 bricks at $300, cheaper than the current oven and more dense. now if I can find blanket and hearth cheap the next oven will cost much less.
                  Plus I will have everything I need. Will make some adjustments to my IT.
                  Cheers Colin
                  Oven 1 Completed
                    The ones I found were on pallets that were rotting and for 50c each could not miss. They are tapers and I cut them in half but they are the same size at the cut. Used the large ones on the bottom and the smaller ones at the top. It turned out fine.
                      Hi Steve
                      The guy I speak of had 2000 of those [tapers]. opted for the arch bricks [less cuts] to achieve my no mortar internal finish. Will do the same again.
                      Will also do the yin and yang glazed symbol again its so cool watching it reappear from the DARKSIDE might make it similar next time to what I do with the keystone of my decorative arch.
                      I often just sit and watch when it clears and watch the keystone just appear from nothing every gust I have had thinks it is so cool.
                      Cheers Colin
                      Oven 1 Completed
                        I used tapered bricks I set the bricks out with a 1.5 mm packer pulled them up tight with a ratchet strap and used the resultant circle as the diameter of the oven as the angle in the vertical arch is the same I then used the taper on the flat and cut the vertical sides resulting in 1.5 mm joints both ways
                          Actually the bricks he had I think he called wedge fire bricks, but I stuck with the arch bricks.
                          Cheers Colin
                          Oven 1 Completed
                            I am not sure what they call the bricks I found but they have one square side and one tapered side. They look like they were meant for building a tunnel shaped structure. They made a perfectly functional dome and I cut them back to square for the floor bricks.
                              Can't wait to see the results of Round Two...
                                3 years off at least. Pretty much wont look any different John but the setting might look a little more like yours this time.
                                BTW where are you at any more progress?.
                                I will work a little on my IT and try hard to work out the cuts before hand like Les did.
                                Am just going to acquire materials as I find them cheap so I can get stuck in when the time comes. The concrete slab will be easier as I wont have existing infrastructure to work around I have a clean slate. Will still use Hebel for my framework as I feel it is so much easier than block. Will change so I have rear and front access to store wood.
                                Not much else I would change.
                                Cheers Colin
                                Oven 1 Completed
