Nice job with the pebbles - I like the look!
Are you planning on a roof? I also built an 'exposed igloo' style and am planning a roof but keep going back and forth on the idea.
Just curious, where did you put your breather?
Nice work.
Looks nice! If you didn't dump most of the toppings from your first pizza into the oven you're way ahead or me
Chimney...mine goes up about 2ft over the top of the dome....with the chimney at the front of the dome the way ovens are built I don't see how it can possibly draft like a fireplace so I'm pretty sure the point of the chimney is just to keep the smoke out of your face so nearly anything you build is "right" as long as it big enough ID.....but my total oven building experience is 1 so take that into account when considering my opinion
Fantastic effort!!Originally posted by stonejumper View PostLittle update picture.
Leaving the tiling for another week and one curing fire left. Just to make sure everything is dry set and i am happy before the final bit.
Starting to look pretty good now. I will be raising the garden next year to the same level as the sleepers.
Looks fantastic! Sorry, only saw your post now.Originally posted by stonejumper View PostStone pebble tiles are done. Grouting left, sealing and that chimney finish?! Still a bit unsure what to do. Dont laught but i actually install ductwork systems for a living, installing flues chimneys and pipework. I will probably end up having a square to round transition with a 125mm round x 500mm long flue with a china mans hat on the top and probably enamled made at some pointMy 42" build: https://community.fornobravo.com/for...ld-new-zealand
Nice job! Neat video too!
