My build, New Zealand.
  • #46
    Helps LOADS mate!
    It really helps to visualize the idea and minimize what I was going to do! I had it in my head to build quite a buttress but the work you did is tight, focussed and apparently sufficient to the task.
    I will move forward more comfortably with the idea of buttressing now.
    Really appreciate your reply and photos, Mark!
    Very kind of you!
    Barry
    You are welcome to visit my build HERE
    • #47
      Originally posted by Baza View Post
      Helps LOADS mate!
      Very kind of you!
      Barry
      Thank you Barry!
      I look forward to following your build.
      Kind regards,
      Mark
      • #48
        Hey Mark! Great build, hope you’re enjoying it during lockdown! I’m down in the South Island planning out a build. I’m trying to decide whether to build a roof or enclosure around the oven. I see you’ve just used waterproof mortar. Would you do it differently a second time? And have you put in a vent for the insulation? I much prefer the look of ovens without a roof or enclosure (and a lot easier/cheaper!) but worry moisture will eventually get in. Cheers!
        • #49
          Hi Dave
          Only just saw your post, sorry! Lockdown has been fine as we have pizza! LOL
          I like it just the way it is, but a roof will obviously be better for waterproofing. As it is, I think I'll paint the outside as some moisture still gets through the plaster. For the moment, I've found it best to cover the oven throughout winter with some tarps as it's only prolonged rain that is a problem. And boy, has it been wet of late!
          Good luck with your project. Shout out if you have any questions.
          Kind regards,
          Mark
          • #50
            Hi Mark,
            I've really enjoyed reading through your build and in particular using the storage heater bricks as this is a path I'm thinking of heading down. It sounds like you have put a lot of thought into your build so you may know the answer to my question - I'm trying to understand what goes into a heater storage brick that makes them different from a standard fire brick. From what I have seen online they add iron oxide to them which is quite bad for you in powder or fumes. But I assume because its set in brick that its not really an issue having food come in contact? Also, just wondering how yours are getting on? is your oven still out in the open? do the heater storage bricks rust at all?
            Thanks,
            Hamish
            • #51
              Originally posted by Ham-ish View Post
              Hi Mark,
              Thanks,
              Hamish
              Hi Hamish
              Thank you for your message. From what I have found online, they can contain magnesite or iron oxide. My floor bricks contain neither so far as I can tell, but as for the dome, almost certainly magnesite.
              Most sand here contain a lot of iron oxide, so I'd be surprised if there's no iron oxide in some of the build materials. With the inner surface of the oven routinely getting exceedingly hot, I would expect that any off-gassing that may occur would have done so by now.
              There is no sight of rust anywhere but the inside of the bricks are no longer a dark red, but more of a grey (for the dome) while the floor has remained a beige brick sort of colour. I'll check it with a large magnet to see if there's any bits that stick to the magnet and will get back to you!
              I'll have to get back to you with whether the oven outlasts me or if I outlast the oven! I've not built any roof over it yet. I might do a pergola with a pull out awning.
              Kind regards,
              Mark
              • #52
                Winter pizza party.
                • #53
                  Time for an update. After having had a pretty wet oven due to lots of rain, I've decided to build a verandah over the oven and patio. I'm almost done, still some finishing touches such as facia, gutter, downpipe etc to do. The unpainted window will become a pair of french doors, so we can access the oven more directly from the dining room.
                  Click image for larger version  Name:	20240707_182722.jpg Views:	0 Size:	377.2 KB ID:	459765 Click image for larger version  Name:	20240707_182737.jpg Views:	0 Size:	368.6 KB ID:	459766
                  • #54
                    Looking great Mark! You'll certainly use the oven even more with the protection from rain Next, I bet a drop-down countertop along the side of the house will appear. I've appreciated all your forum constructive comments over the years...glad you joined our WFO family.
                    Roseburg, Oregon
                    • #55
                      Thank you Mike! Much appreciated. And thanks for the work you do as moderator. I'm a moderator on a busy international photography forum and, while there's about 8 of us, it can be quite a job sometimes!
                      • #56
                        Four years out and still improving the setup! This will certainly up your entertainment game Mark!!
                        • #57
                          That is looking really nice! Once you get your roof done you'll wonder how you lived without it. Are you planning on putting up any sides?
                          Since we built ours some of the lots around us have been cleared and built up with multi-family dwellings. Having the translucent side walls is nice as we can chill out around the oven with a little privacy.
                          My build thread
                          • #58
                            It sure will John! We're lucky in that it's the most protected area of our garden and no close neighbours, so probably won't need any screening. I may end up adding a bit of a wind screen on the South side, but will see how we go first.
                            • #59
                              JR, no sides at this point. But, will add a pergola to the front of it and plant something, maybe a grapevine or something aromatic. We're lucky in that we have no real close neighbours and plantings between us and the closest neighbour, so pretty private really. We have paddocks to two sides and only the one closer neighbour.
                              • #60
                                An update. House now painted, new roof, verandah completed. Deck now complete at this end of the house so direct access through the new door to the dining room and kitchen, where there used to be a window. Click image for larger version
ID:	468659 Click image for larger version
