And so that brings us up to last night which was Day 5 and our final during fire which would bring us up to pizza cooking temperatures
i knew I had to let the dome clear to know I hit temps that seems to be the consensus form reading through other forums that you reached a full cure if and when it clears
and we’ll into an hour of letting a fire build we began to see the roof of the dome clear the fire was burning hott
we were seeing mid 5s at the very bottom to around 800 + at the very top
and well it finally happened …….
WE MADE PIZZA!!!!
I cooked up some amazing garlic marinara sauce whipped up a couple batches of dough and we made our very first pizzas and boy did they cook quick !
the oven worked tremendously and more on the smokeless aspect the oven was performing so well all you saw coming from the chimney was the heat waves this oven was on top of its game!
We made two margharitas pies and one traditional plain
just had some left overs writing this and I’m sad I cannot make more pizza tonight since I will be doing the shell this afternoon and letting it sit for another week before firing again
idk if you will see in any of the photos but I wrapped my chimney in the towel I used as a pad for the tarp over it
it worked well for a temporary “insulation”
until I build the really chimney surround I am going to temporarily build a box to go around the chimeney and either use left over blanket insulation or fill with left over vermiculite until the new chimney surround is built prolly in a month or so
WE MADE PIZZA!!!!
