Re: Michigan WFO
I'm not certain it's that important. You're not providing clearance to combustibles: I don't really see any reason it can't touch.
Re: Michigan WFO
Could you snip away some of the metal, in place? Might weaken the stud slightly, but you can add reinforcement elsewhere.
Re: Michigan WFO
I don?t know if the metal will expand enough to compromise the flue mortar joint, but it doesn?t take much to crack the stuff. Can you remove the offending stud and bend it in a little to get relief? Might be better being safe. Although, I?m assuming you are going to fill the chamber with vermiculite, so a little smoke escaping would cause no harm.
Les...
Re: Michigan WFO
I may have made a mistake. Over the winter, the chimney flue liner got knocked with the tarp. I took it off this spring to reset it.
I framed the oven with steel studs for the enclosure. When I went to put the flue back in, I realized it was bigger than I planned. It touches against the steel framing. I know there is supposed to be a gap all the way around. Will it cause a problem to have the flue touch against the framing like this? (Keep in mind that the flue is mortared down, and the framing is bolted to the cement slab already!)2 Photos
Re: Michigan WFO
Very funny. I wanted to go the "igloo" route, but my wife wanted me to block the view of the fence!!!
Re: Michigan WFO
Mike - I didn't go this route, but I think you got it on the run. I'm going to enjoy watching your "wrap". I wanted to go that way but the wife didn't want me to block her view of the yard
Re: Michigan WFO
Working nights this week, so I was able to take advantage of a nice day (sleep is over rated!)
I worked out some framing for the enclosure. I've never worked with steel studs before. I actually like them quite a bit. I used Tapcon screws to secure the track. I found 20 g steel studs locally, not much more money, so I decided to use them for the supports. The steel seems to be very forgiving. At first, seemed a little flimsy. As the walls tied into each other, it became quite sturdy. Each stud brought everything in real plumb and square. Nice to work with. I've been luck, no stitches (yet).
I don't own a chop saw, so I cut everything with a pair of Aviation snips. It's a little tough with the thicker steel, but I couldn't justify another purchase.2 Photos
Re: Michigan WFO
I Love your arch, can't wait to start my oven, not far away now!!
Re: Michigan WFO
Sorry I missed your question Mike. I have no regrets. I wanted the entire counter to be the same level - if I brought it up to my hearth (which in hind sight, I should have made it a little bit higher), then it would have been a pain to BBQ.
Les...
Re: Michigan WFO
Les, I raised this question a few weeks ago in a discussion. Your thoughts?
http://www.fornobravo.com/forum/f8/c...oven-6839.html
Re: Michigan WFO
Nice job, Mike! I like the keystone. I'll have to show that picture to the boss. And congrats on being done with the arches! May they stand a thousand years.
Have you decided how to raise the landing? I'm debating whether I should use concrete or look for a tile or slab of some sort that will fit in that space.
Re: Michigan WFO
Thanks, Dino. I'm happy with the brick choice. Not sure what I'm going to do to fill the void between the arch and in front yet. I need to raise the level up a few inches to get in the same plane as the oven floor.
I bought the limestone key just like that at the local brickyard. It's a standard keystone used for house brickwork. They had several sizes and styles (beveled edge, etc)
Re: Michigan WFO
Looks great Mike! I love the colors in the brick. And the detail of the limestone keystone is great. I think you are doing it the right way: Figure out your decorative arch 1st, then build around it. My plywood forms look exactly like yours: some strips of duct tape to help round it out. Works great. Your deco-arch makes a nice statement.
Good weather is just around the corner for you Michiganers, I think you'll be done with the enclosure in no time. Say, did you cut that limestone "key" into that shape? Its really cool. Keep up the fine work, Dino
Re: Michigan WFO
OK, I'm back at it! Our weather this spring has not been very conducive to building. I've been filling my time pouring over the old threads of this forum, changing my ideas a thousand times.
We plan a walled enclosure with a stone veneer covering it.
Today, I build a decorative arch from Old Detroit brick, using a limestone keystone. It still needs to be cleaned up. I'm really happy that's my last arch!1 Photo
