Re: Raffy's WFO Build
Thanks Raffy.
I am trying to figure out where to locate it in our house in Valle. The best location is against the perimeter corner wall, but I am not sure about the setback requirements. Maybe it can be considered just part of landscaping.
Btw, do u mind if I ask how much u spent? I am talking to a small contractor to build it after I finalize size and location. I will put a tile roof (i have spare tiles), just so there's less chance of sparks flying and so it doesn't get so wet. I'll also include a side table, which you need actually. I am planning to make the oven 30-32 inches. I hope this is big enough to roast a small pig. I've cooked lechon a few times in our 30inch gas oven.
I bought a big tarp for our oven in tali to prepare for rainy season. It has a roof, but rain there flies horizontally. The clay oven was so cheap to build. I spent only about 8-9kpesos on it, including the base and the gi roof. I had left over materials from our house build and labor was done by us and our gardener. If I fire it long enough (1-1.5 hours). Floor temp gets up to 900F and the pizzas take 2 minutes. I've tried using bagasse (my friend grows sugar and makes muscovado) to fire the oven but it's really not ideal. It burns too fast and has a lot of residue which actually hampers airflow. It works well, I get slightly worried though when I bump the walls with the bakers peel.
I wanted to ask, are you required to have your chimney so high?
Paella in the oven, I will try sometime. Lechon is actually next on my agenda.
Tx!
Thanks Raffy.
Tx!
