Re: Show us your Door Thread
That is a great door and the rollers will be a feature of many doors in the future I expect. Evolution at work!
I think your door is a beauty, and is sure to inspire others.Originally posted by brissie View PostI think I used much or your design in my door. Thanks
So many good ideas are on this site. I mixed up your inspiring door, cobblerdave's, and Geenman's door to name a couple that inspired me. Then melded it with my own experience and knowledge.
I hope the addition helps someone create some interesting design choices.
Cheers,
Steve.
Awesome idea and a great jobOriginally posted by Rbhumbert View PostWanted a durable insulated door that I could hinge down and or roll out for loading bread without having to pick it up and remove it. Note the little rollers at the bottom which allow it to lay forward and or pull forward without dragging on the hearth. Works great, no more picking up a heavy, hot door just to load multiple loaves of bread.
Wanted a durable insulated door that I could hinge down and or roll out for loading bread without having to pick it up and remove it. Note the little rollers at the bottom which allow it to lay forward and or pull forward without dragging on the hearth. Works great, no more picking up a heavy, hot door just to load multiple loaves of bread.5 Photos
I think I used much or your design in my door. ThanksOriginally posted by mrchipster View PostI only use mine for baking bread and such.
The window (pot lid) will become covered in condensation and will drip water on the inside until the temp equalizes.
I have a 550 degree oven max when using it so not sure what the top range is.
BTW ... I do use it in the winter at -10F so the temperature spread in the winter is well over 550F degrees. No Problems with thermal shock so far but I take care not to drop the door in the snow when it is hot.
Cheers,
Steve.Last edited by brissie; 03-07-2014, 06:05 AM.
Hi ATK406Originally posted by ATK406 View PostThat "pot lid" door is awesome. Any idea what the thermal limits would be with something like that (i.e. what would be too hot)?
The door is great and use it the most. The photo shows the door in "blast door mode"
and inside face is stainless steel around the port hole (pot lid). The photo shows the door pulled back from the oven dome entrance. The thermometer gets to 200c - 250c max. Most of the heat goes up the flue. And think the door would reflect back some heat. It also looks good
My build has a a flared entrance, (its not brick) and has a couple of inches gap around the door in the photo.
Note that it works equity well for baking, and bread, though I am still in the experimental stage with the oven.
Cheers.
I only use mine for baking bread and such.Originally posted by ATK406 View PostThat "pot lid" door is awesome. Any idea what the thermal limits would be with something like that (i.e. what would be too hot)?
Good to see someone built a portal pot lid door, I never use mine with a live fire but nice job on yours.
Just thought I should link to page 20 on my build. I created 3 doors.
I used technology that was quick and easy for me. I did not want to spend days or weeks just for doors. The insulated doors have good thermal conductivity characteristics, as metal is limited to the hot face side.
Hope it helps someone.3 Photos
Just moving this up to to took ages to find. Looking for ideas.
Thanks for the advice. Have not tried the pizza directly on the brick yet--have to make the right tools. Eventually I will find the right routine and make some very special pizzas---maybe? What we made on Sunday, put smiles on the faces of the youngsters and oldsters that showed up. A fun for all evening --a break from the summer heat!
Nice door Mikku. Very tidy indeed.
You might get your crust to puff some if you back the toppings off a bit from the edge but they do look tasty!
Could not find the photos--now OK.
scaffold WFO cover for week-end.
wood pile structure to be crashed and rebuilt.
chimney cap to keep rain out during a downpour! Man did we have rain both Saturday and Sunday--but oven still dry!
View inside "crack less" oven after maybe 15 hot burns--still "Crack less castable" Harrah!!
4 Photos
Still no stand for the WFO, use pipe scaffolding and corrugated sheet metal to keep the rain away... Also doing pizza "Japanese way" --ON YOUR KNEES--
Brickie might like that comment! At least I have settled on a location for the oven. Need to crash my wood pile structure and make a larger one that will accommodate the oven in the same construction...plan to make it out of 2" square tubing and c channel. Should be cheap enough and keep the weather away. That is the most important thing anyway...not trying to make an architectural statement. Just a simple build.
- Likes 1
