Are you using a "lazy susan" type design for the IT to achieve the flattened top?
I think with the lazy susan IT the flattening happens naturally as you get higher up depending I guess on the offset of the pivot.
I am going with an elipse shape for the dome - 18" height - so I am hoping the cut will be right. I expect I will have to do some trimming as I go up.
With those straight sided arches I am not sure that can be achieved for the rounded part.
..and I am headed to Whistler for the weekend anyway!
regards
Aidan
In Kens vent is the opening for the flue just 4.5 ". Is there a good reason not to bite off a bit more than half a brick - or does it matter?
