Re: Budget Build 36"
Gudday Bevan
Looking great! I'm particular taken by the pics of the oven inside. Because of the thinness of the pavers hardly any great gapes. Not like you would expect with full thickness brick! I've seen a paver/bulster built oven and I know the gapes at the top would have larger ones but its not important. If you had to tap your last keystone's in with a mallet they should be tight enough.
Sorry to hear that the blow up ball was a pain to use , I'm now of the opinion that it would only be of use in say the last 2? Rows. What do you recon?
Good idea to use those bricks to force the sides up by the way.
I noticed 2 bricks hanging around in a few pics is it those, or are you planing to use your antique bricks as a feature on the entrance?
Gudday Bevan
