Jim's Build for the Common Man
  • oasiscdm
    • Jan 2012
    • 1239
    #61
    Re: Jim's Build for the Common Man
    Another one asking the same question on the same day.
    Read me.
    If you are loading up the arch then you would be advised to buttress, for a stainless flue you will be wasting your time.
    thanks for that Alan. Interesting reading. and i'm using a stainless flue so that comment helped also.
    Cheers Colin
    Oven 1 Completed
    Oven 1 and surrounds
      Isn't the arch in question is the entrance of the oven dome and is in fact buttressed by the dome itself.?d..........
      Yes, it is.
      Further an arched entrance way/ chimney structure,that was built separate from the dome ie has a heat break from the dome requires buttressing?
      Yes, it does. IMO .
      • jimkramer
        • Jun 2009
        • 143
        #63
        So I realized I won't be able to taper my entry arch bricks with my 10" HF saw. Unless I raise the blade, run the brick through, flip it, run it through again. Or I guess I could do it by hand with my angle grinder and diamond saw. Though it would be difficult either way to keep the angle consistent. Is it worth the trouble? I suppose if they're not tapered, they'll fall out more easily.
        So, just to make sure I'm clear on the reasoning behind this...I've been advised not to follow the original FB plans to make a straight entrance with a piece of angle iron. Is that because the heating/cooling iron will degrade and bend in a few years, causing shifting dome bricks?
        Here's mine:
        http://www.fornobravo.com/forum/f8/j...man-15992.html
        • brickie in oz
          • Mar 2009
          • 3445
          #64
          The angle iron will rust out in now time, it will also distort with the heating/cooling cycles.
          My Build.
          Books.
            • 2848
            #65
            Gudday
            I don't know about twisting and distorting but I can tell you in the end they will rust out. I will be tapping them out in a few years time and replacing them but I expected that when I built it.
            If you get hold of splits , thinner bricks , you'll find the gapes are thinner as they span over more bricks. Check out my own oven the outer arch was constructed of clay pavers. No cutting required. Have brick to brick contact on the inside edge of your brick and gravity will do the job of keeping the arch together.
            If you do an arch of this shape it will be alright as the dome entrance as the dome buttresses it but outside entrance arch you will need buttressing
            • deejayoh
              • Jul 2010
              • 1893
              #66
              Actually it is surprisingly easy to do this. Just eye ball the cut on a sightline with the blade.
              My build progress
              My WFO Journal on Facebook
              • jimkramer
                • Jun 2009
                • 143
                #67
                I put off starting the arch and worked on the sixth chain. As those inverted V's pop up...how important is it to fill the voids on the inside of the dome? WHen I put on too much mortar, the bricks didn't line up/squish up right. Not enough mortar, and I get them voids. It gets messy filling the voids on the inside, so I'd rather leave them be if I can.
                Question #2, I got a brick that's not level, one corner is popped up about 1/4", which makes the next course out of level. Can I take a grinder to it, or will this possibly loosen up other bricks? Is it better to chisel it out and grind it down? Either way will disturb other mortar joints, I suppose.
                Here's mine:
                  • 2848
                  #68
                  Gudday Jim
                  Round ovens and square brick have been around long before bricksaws an other fancy stuff. Live with the dreaded Vs clean the mortar off the face and get on with it.
                  3 odds yrs and plenty of feeds and long stop thinking about it
                  The mortar will be your glue till that last brick goes in the gravity take over and structure depends of gravity for its strength. The mortar now holds the bricks apart and be the cushion when the oven expands and cools.
                  That brick that pokes up a bit perhaps you would be better to adjust the bricks above rather than disturbing it and the surrounding brick.
                  • mrchipster
                    • Apr 2010
                    • 1502
                    #69
                    I agree with Dave, shave off the 1 or 2 bricks above the one that is sticking up, no one. Will ever know but you and it will keep every thing below nice and solid.
                    Chip
                    • jimkramer
                      • Jun 2009
                      • 143
                      #70
                      Okay. Construction has started for the 2014 season. I am determined to win the Longest Time to Build award. Though I might have to cave in and finish it by this fall. The first thing I was greeted by when I took off the tarps were about a dozen mice. Some of them didn’t even scatter, as if it was I who was invading there space and they were waiting for me to leave. My cat got at least one of them.
                      The second thing I noticed is that my insulation got soaked. I had two tarps on the top, but for various reasons, they sagged under puddles of rain a few times over the last couple years. Not much I can do about that now other than dry it out and be more careful. The insulation seems to be structurally sound, even when wet.
                      Questions: Since my dome is not a perfect circle, I have to make a decision about the inner arch. I only have three vertical bricks down - I haven't put down the bricks that will follow the arch. As it intersects an imperfect circle (dome chains), I believe I will have that “tear drop” effect” as the dome chains have to reach to the arch. I could correct for this by having the arch bricks reach into the dome, more than the vertically stacked bricks below them. Would that cause any problems? I'm concerned that would cause lateral support problems for the arch. I’ve also seen people add a partial brick on the dome chain above the arch to correct this. Is that a better solution?
                      Also, the water pump on my HF saw doesn’t hit the blade. The water gets there, but after it rolls off the brick, about ?” away, which I think wears the blade down faster. Anyone have any luck redirecting the water? I tried widening the hole with a pin, but that didn’t help.
                      Here's mine:
                      • mrchipster
                        • Apr 2010
                        • 1502
                        #71
                        Because the pump is easily clogged i just used the garden hose with at nozzle directed to the blade of the saw. I put an in line ball valve mounted to the side of the saw. You could hold the nozzle or in my case a piece of plastic tubing where you want it with Zip ties or drill a hole where you want it in the spray cover over the blade, that way you can get as little or as much water as you want and just use the water from the house only when cutting. if you are worried about overflow tap in a tube to catch and divert the extra water away from your work area.
                        Chip
                        • deejayoh
                          • Jul 2010
                          • 1893
                          #72
                          To your saw question - Take the blade off the saw, and reach up under the hood. The water jet is a piece of copper pipe that probably got knocked askew. Just bend it/re-aim it so it hits the blade.
                          My build progress
                          • GianniFocaccia
                            • Jun 2009
                            • 1645
                            #73
                            I had the same problems with my HF saw. On numerous occasions I submersed my pump in a sink full of warm water and ran it for awhile. Each time this helped. I also took a piece of flexible wire and ran it up into the jet. This also accelerated the water pressure of the jet.
                            Regarding compensating for your dreaded droop, extending bricks into the dome on higher arch courses will not present any problems. Virtually all of the arch thrust is vertical. Any small portion of the inward-extended bricks will be supported by the dome in a strong, cohesive init. Of course, instead of adding another course, you can make it up in mortar over the course (!) of several courses. Ha! Really, I wouldn't worry about it much.
                            • jimkramer
                              • Jun 2009
                              • 143
                              #74
                              Building the inner arch- can anyone help me understand how to determine the angle of the slope to cut into the arch bricks to accomodate the dome bricks? I thought I had it figured out by holding a string to the dome center, then extending to the arch bricks. But this doesn't seem quite right in practice. Should I post pics to illustrate my quandry?
                              Here's mine:
                              • mrchipster
                                • Apr 2010
                                • 1502
                                #75
                                Put a mark or knot in the string where the inner radius of the dome is. (A) This will help you with the shape of the arch brick for the cut that goes from the arch opening to the point on the arch brick. Put another knot or mark on the string at the outer radius of the dome. (B) This mark will set the angle for the top of the pointed part of the arch brick (the area that contacts the dome bricks for the next layer.
                                When getting the position for the bottom cut, you can see that the (b) location is insignificant. But both A and B are important for the top cut. And the B position determines the top cut, the A positions determine the inner surface of the dome, and the related lower or inner cut angle.
                                See the drawing it might help.
                                Chip
