Re: Jim's Build for the Common Man
Jim,
It's easy. I made two identical wood templates of the interior dome profile I wanted. The first one I used periodically to keep each course consistent with the profile. The second one I cut vertically to account for the vertical inner arch.
At the center of my inner arch form, I laid a full firebrick. For lack of a better term, I call this brick my TDC (top dead center) brick. Then I took my trimmed dome template, placed it against the top of the 7th course and made a mark (A). You can't see it very well, but it has an arrow pointed at it. I used this mark to determine the red line (B), which extends from the floor center of the dome past the face of the inner arch. This would ensure that the top of the course immediately above the inner arch would stay level all around. I think this is the angle you asked about.
The last angle was simple: just match the curvature of the template to end up with an inner-facing (down) brick angle that matches the rest of the dome on that course.
I hope this explains it. If you have more questions, just holler.
John
You can find more images here (post #34)
Building the inner arch- can anyone help me understand how to determine the angle of the slope to cut into the arch bricks to accommodate the dome bricks?
John
