Re: Mississippi 44"
My damper is made from 3 insulating firebricks all silasticed together.
There is a sacrificial metal skid plate also silasticed to the bricks.
I also have a metal skid plate in the damper entry floor too.
The part of the chimney where the damper slides into also has insulating fire bricks at the same point, I figured it would stop a lot of heat transfer and heat from going up the flue, so far it has worked a treat.
The skid plate on the damper has suffered from the heat but surprisingly the silastic has help up.
