Re: Mississippi 44"
I angled the cuts for 4 rows. The 5th was a little to steep for my HD saw. I had hoped to go up to where the width for the flu transition would start at about 24?. The 4th row left me at about a 25 ?? width. Close enough. The side walls of the flu transiton will start here.
![](http://i438.photobucket.com/albums/qq105/GulfCoastScooter/Oven/0062.jpg)
On row 5 I turned a row up, which allowed me to lay the brick on its side at the saw to cut the curve to fit the arch.
![](http://i438.photobucket.com/albums/qq105/GulfCoastScooter/Oven/0014.jpg)
To get the angle for this cut, I had to figure out where the transition would end. I stopped it about 18? above the arch. I decided to make the inside diameter of the transition 11 ?? X 11 ??. The distance between the entry arches was 11 ??. This allowed me to uncomplicate the cuts by keeping the front and back walls vertical while only angling the side walls.
![](http://i438.photobucket.com/albums/qq105/GulfCoastScooter/Oven/0162.jpg)
EDIT: for the most part it is level it is just by this time of day " I get a little sideways". And I'm the one who has to aim the d__n camera
![Big Grin](https://community.fornobravo.com/core/images/smilies/biggrin.png)
