Re: Texman Build
I've had a bit of a look and I can't seem to find what mortar you used. Was it homebrew or proprietary?
Texman Build
Re: Texman Build
About time you posted your head in the oven photo Texman. You know it is a ritual? The WFO gods get their sacrifice one way or the other. Post them during the build or your repairs later. Your choice Novaslo.............Glad to hear your repairs went well Texman.................I think The WFO gods will be happy
Re: Texman Build
That's funny.....I bet your son or your wife was cracking up!
Based on how my build has impacted my life as well as my family's, I am sure they are quite involved.
Your build is sure turning out great!Leave a comment:
Re: Texman Build
Should have put the boy in there! I want to see the "after" pictures when you came out...Leave a comment:
Re: Texman Build
I got the patch done-i hope. I haven't fired it yet but i pumped enough fire-pak in the margins that it oozed when i pushed into place. I think what happened is a combination of a tight door and a crack in dome to inner arch. it was about a 3/16" crack in the dome at the widest point that does not exited to top of dome. So you have to get your head in there or use a mirror to see it.
Warning about the pics though-dont look if you are claustrophobic !
I finally talked myself into getting in there. The really strange part is you can't get yourself out without help. My son had to pull me out since my arms are above my head in the oven to work the repair.
DJ-as usual you are right again-grind the bricks for sure. I have a lot of experience with that.
Texman4 PhotosLeave a comment:
Re: Texman Build
That sucks Tracy. I might just grind the bricks to fit the door. Easier and cheaper in the long run! IIRC, you have a pretty snazzy door.Leave a comment:
Re: Texman Build
Tex, I hope the repair goes well for you. The pictures of the damage made me feel sick and it's not my WFO. Keep us posted on how it goes.Leave a comment:
Re: Texman Build
Fire-Pak is available from WESCO Refractories in Mansfield Texas $6.15 a tube
phone 817 332 1589 no website for sales (you gotta call them.)
I will let you know how it turns out. Probably use to seal the cracks in dome as well.
TexmanLeave a comment:
Re: Texman Build
i think i knocked them loose with my HEAVY steel door. It is really tight and i have to work it into place. all that rocking with something that heavy wedged against the arch is stupid. I will be grinding or replacing that door.
Do you sale the Fire-pak?
Re: Texman Build
Look for a product called "Fire-Pak". It is in a caulk tube and is made for repairs like this. Did you knock them loose with a log?Leave a comment:
Re: Texman Build
I have a couple of my inner arch bricks that have come loose. I am thinking due to the small margins that the only way to repair is a hi temp refractory caulk that i can pump into gaps on either side.
What is the right product and is this the right way to repair?
Texman3 PhotosLeave a comment:
Re: Texman Build
Hey Tex,
Where ya been? Thought you dropped off the forum. Glad to see you are back.Leave a comment:
Re: Texman Build
It wasn't that long ago we spoke on the telephone and you hadn't even started yet. Now you have the model kitchen........OUTSIDE!
Re: Texman Build
Spaceman
Thanks for the compliment. Looking forward to your build, so post lots of pics and let me know if i can help.
