Re: 42" Pompeii in S. Louisiana
I've run into an issue with the bricks. Now that I am laying a row across the front, my spacing is a bit off. How should I handle this? My inclination is to trim about a half inch from the end of the two bricks that fall on the center line. On the next row, I will trim the same amount from the brick that straddles the center line. Does this sound like a good idea that won't be too noticeable?
. The sooner that you come to that realization, the happier you both will be
