Re: K79 Oven Build
Hello All,
I'm wondering about my 3" of Fiber Blanket that I'm going to wrap my oven in once the dome is complete. Do I wrap it and compress it with chicken wire to hold in place or should I make sure not to compress it against the oven dome? Since I'm doing an enclosure and burying it in vermiculite I don't need to put anything else over it correct?
Re: K79 Oven Build
To be honest, I didn't do any "flue math" when I built my vent. That's way above my knowledge base.Originally posted by K79 View PostShouldn't the opening under his anchor plate be 50.26 sqin to maximize the effectiveness of his 8" chimney. Since a 7" chimney can handle just over 38sqin would that have been a better fit????
After spending years as a kid playing with campfires and lighting fireplaces, I was reasonably sure that if I gave the heat a fairly simple, direct path, physics would take care of the rest.
I can, without a doubt, confirm this. I never get smoke out the front of the oven. When the chimney heats up after a couple of minutes, the smoke is literally sucked out of the oven. It's fun to see it accelerate through the flue. There are some serious convective forces at work.Originally posted by david sActually a bit of restriction can be a good thing because it creates a Venturi effect and increases the velocity of the flow in that area.
If you are sweating over a few sq. inches, relax and don't get too caught up in the math; we aren't building cooling towers for nuclear reactors
. Give yourself a reasonably sized vent opening and it'll work (as it has for thousands of years).
Re: K79 Oven Build
Mine is an exposed igloo and not enclosed so space was not an issue. Landing is about 14-15". I cut small sections/slivers out of the brick alot of feathering like you did on the floor arch then took and angle grinder with a cupped diamond wheel to finish final shape.
Re: K79 Oven Build
That's awesome. The only issue I have is space. How long is your vent landing? Must have used a brick and a half at least. I'll take a look at your album. How did you make those nice round cuts in the brick? If I build mine like Ken's that would leave me just under 3/4" in front of my chimney to put my 1/2" concrete board. Your method the firebrick would be sticking out beyond my concrete board. hmmmmOriginally posted by UtahBeehiver View PostK79 Maybe this will help. This is how I fasten my anchor plate. First two pics are looking at the bottom. I cut out the bricks to inset the anchor plate. This was the top my chimney. There are other pics on my picassa album.
Re: K79 Oven Build
K79 Maybe this will help. This is how I fasten my anchor plate. First two pics are looking at the bottom. I cut out the bricks to inset the anchor plate. This was the top my chimney. There are other pics on my picassa album.4 Photos
Re: K79 Oven Build
Re: K79 Oven Build
Ok all, I'm hoping to resolve my chimney/vent/flue issues today so I can finalize my foundation pad and block wall design.
I understand that 15% of my oven opening is the minimum size I want for my flue. My oven opening is 208sqin. Therefore I need a minimum of 31.2sqin of vent opening. A 6" ss chimney only gives me 28.27sqin. A 7" ss chimney gives me 38.48sqin. So I can go with either a 7" or an 8". Now I'm trying to figure out what my anchor plate is going to rest on. I've been looking at Ken524's design and this is where I get a little confused (unless I'm trying to go by the books too much).
Ken's oven is 42" (btw, thanks for letting me use your oven as a guinea pig Ken)
In view one (and I'm assuming some numbers here but I think I'm close) Ken's flue vent starts 9 bricks wide and looks to be 1/2 brick in width. This gives a flue vent area of 83.25sqin. at the bottom. It then tapers to 5 bricks wide at the top giving about 46.25 sqin (view 2). Now in View 3 Ken builds a "landing" for his anchor plate and now makes the opening only 4 bricks wide giving about 37sqin of flue vent for his 8" ss chimney which can handle 50.26sqin. (view 4).
This is what confuses me. Shouldn't the opening under his anchor plate be 50.26 sqin to maximize the effectiveness of his 8" chimney. Since a 7" chimney can handle just over 38sqin would that have been a better fit????
Re: K79 Oven Build
I agree. An outdoor chimney doesn't function like one for an indoor FP/stove...too many dynamics outside. It's more about giving smoke a place to go besides the front opening.Originally posted by david s View PostWith a front flued oven I don't believe it is.
Re: K79 Oven Build
Looking good! Are you getting rid of that sliver on the first course?Originally posted by K79 View PostSome progress. I can't wait for this weather to break !
Re: K79 Oven Build
Re: K79 Oven Build
I agree. The shallower the entry is the easier it is to work the oven, but you must make sure it is adequately flued.
