My 40" Inch pizza oven in Florida
  • kbartman
    • Feb 2013
    • 572
    #256
    Re: My 40" Inch pizza oven in Florida
    Ummm....stone.
    I would like stone but I'm trying to keep cost down.
    Today I'm building the forms for the chimney arches. I hope to make some much needed progress. August get together planned
    Respectfully,
    KB
    My build
    • oasiscdm
      • Jan 2012
      • 1239
      #257
      KB
      Nice dome, seems there are a few finishing presently. It looks great, nice tight fitting bricks.
      Must ask where's the head in the oven photo. I'm told it is a ritual.
      next photo posted must be the body in the oven shot.
      Cheers Colin
      Oven 1 Completed
      Oven 1 and surrounds
      • kbartman
        • Feb 2013
        • 572
        #258
        Originally posted by oasiscdm
        KB
        Thanks Colin,
        This is purely ritualistic. I crawled back in , I didn?t get any pictures when setting the keystone and cleaning the inside of dome, I was scared then and only put one arm and head in. This time it?s official, both arms.
        Finished the outer arch chimney support form today, and bought some insulating brick to set the arches on.
        Respectfully,
        KB
        My build
        • kbartman
          • Feb 2013
          • 572
          #259
          I got a little accomplished today.......I set the form, it took awhile the face of my inner arch was tilted so it made leveling and squaring difficult.
          I also cut some brick and did some dry fitting. I'm beginning to realize the cost of my cut to fit approach, aka. "Geometry for dummies". I'm just wore out my fourth blade. I hope just one more at the $60 bucks a pop, although I should return my buddy his saw with a new one on it.
          Respectfully,
          KB
          My build
          • Bec1208
            • Nov 2012
            • 416
            #260
            What are the dimensions of the entry? Looks like about 22" wide and maybe 16" high. No guess as to how deep. Glad you are ahead of me in your build as I have learned a great deal following your thread. Bruce
            Link to my build here:
            http://www.fornobravo.com/forum/f6/3...lly-19181.html
            Selected pictures of the build.
            https://picasaweb.google.com/1168565...g&noredirect=1
            sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
            • oasiscdm
              • Jan 2012
              • 1239
              #261
              Hi KB
              I am curious to how you are doing your arch. You said on my thread that you are doing yours straight but maximizing the reveal.
              Can you describe yours maybe include measurements. How deep, then again I could wait for more pictures.
              I was thinking if I don't flare mine of running mine around the inner arch with a gap between it and the outer structure.
              Cheers Colin
              Oven 1 Completed
              • kbartman
                • Feb 2013
                • 572
                #262
                Hi KB
                Ok guys these ain't no CAD drawings, although they are one step above a paper napkins. :
                K79 is probably laughing is his boots right now .............. Hope this helps and you can make them out.
                Respectfully,
                KB
                My build
                  • 3885
                  #263
                  KB,
                  I think that I see what you are designing. It will work fine if you slide the vent opening forward. In my opinion (with a heat-break) the arch needs to be completed front and back to be structurally sound.
                  I may be a little off in my reasoning, so some "dry stacked pics" might help .
                  • oasiscdm
                    • Jan 2012
                    • 1239
                    #264
                    thanks KB
                    perfectly clear. Wanted to know if rear of brick was rebated around inner arch. Did you follow the curve. How high before your glue transition and will you do it like sharkey did his.
                    Cheers Colin
                    Oven 1 Completed
                    • kbartman
                      • Feb 2013
                      • 572
                      #265
                      Originally posted by Gulf
                      KB,
                      Gulf,
                      I'll try to post more dry stack later, the vent transition will have a complete arch on both sides. Moving the vent towards the rear allows the needed 4" for chimney wrap around flue.
                      thanks KB
                      Colin,
                      Yes the rear brick will be have a 1" inch overlap and a 1 1/2" into the reveal leaving a 3" reveal. There will be a 1/2" thermal gap which will be filled with fiber rope and sealer. I will have to look at sharkey's to see what he did. I did follow the curve.
                      Respectfully,
                      KB
                      My build
                      • oasiscdm
                        • Jan 2012
                        • 1239
                        #266
                        Hi KB
                        Might wait for your dry stack to get a better idea. eg. will have complete arch on both sides.
                        To get the vent curve Sharkey has on his vent I was looking at reversing arch bricks, someone else did this but I cannot remember who that might have been.
                        Cheers Colin
                        Oven 1 Completed
                        • kbartman
                          • Feb 2013
                          • 572
                          #267
                          Originally posted by kbartman
                          Wow!!!
                          Very impressived a flared entry at rocket speed. Congratulations on closing the dome ......Where is your ritualistic pictures? Must post your head in the oven I?m told.
                          Originally posted by jbruning
                          Photos of the vent/entry construction.
                          Colin, check out jbruning's thread, done a flared entry.
                          Respectfully,
                          KB
                          My build
                          • K79
                            • Nov 2012
                            • 391
                            #268
                            Hey those look pretty good to me.
                            Link to my oven build on YouTube:
                            http://www.youtube.com/watch?v=Ujb7lqVcSzQ
                            • kbartman
                              • Feb 2013
                              • 572
                              #269
                              I wish I had CAD....and the pizza coming out your oven
                              Ok guys, hope this gives you a little better idea of what I am trying to accomplish. The vent offset looked better on paper, what you all think?
                              Respectfully,
                              KB
                              My build
                              • deejayoh
                                • Jul 2010
                                • 1893
                                #270
                                I'd use the next brick course to get an offset. Seems like that would make it easier to get the mortar right.
