42" Pompeii in Paso Robles Ca.
  • Novaslo
    • Dec 2013
    • 279
    #61
    Re: 42" Pompeii in Paso Robles Ca.
    Originally posted by hubert_s
    I would recommend to dry fit two bricks. Use the IT to set the first one and put shims under it to keep it in place. Then, do the same for the second brick. Now, look at the vertical joint between them. If the sides are parallel, you are ok. If there is a V that opens to the top, your bevel angle is too large. If the V is inverted, the bevel angle is too small. Make an adjustment and try again. Save the two bricks that did not fit well, either for near the opening where nobody will see or for when you need smaller bricks.
    I think the reason why you have to flip every other brick is because your bevel angle is too high. I suspect that if you installed them without flipping, you would get a bigger right-side up V than the inverted V you would have gotten at zero bevel angle and that is why you are flipping them. If you have precut a bunch of bricks for the remainder of this course, try them one course higher. You might get lucky and have very little V.
    I don't know what tool you use to set the bevel angle. I posted earlier about the method I used to eyeball the adjustment with a tilting saw head. If you use a protractor and have difficulty getting the angle right, try measuring the height of the jig at a known offset from the pivot point instead. If you measure at 4x your brick height from the pivot point, raising or lowering the jig by 2x the gap observed during dry fitting should get you close.
    I noticed that you used a small brick to keep the joints staggered. To make a smaller brick fit correctly, both bevel and taper angle have to be reduced. If you don't want to change the bevel angle on the jig and can live with a small V, you can put a brick shim between the fence and the brick to reduce the taper angle without having to readjust the jig. If you don't reduce the taper you may end up with a bigger gap on the inside of the dome as the outsides contact first. Of course, if you cut all your tapers on the low side, there is probably enough gap on the outside where you don't have to adjust the taper for a smaller brick.
    Hang in there, I am sure it will all come together soon.
    Hubert,
    Thanks for the lengthy reply, I really like how you are breaking it down for me in simple terms. That will really help.
    I am more comfortable with laying the bricks, mortaring etc. The first day was a hot mess. This weekend, I will use your advice to get this right. Fortunately for me on yesterdays effort, I spent a good amount of time making sure that my inside top line was nice and level. This should make for really good transitions and smooth gaps for the next level.
    It really helps to shim each brick, this I did not do the first day.
    I am learning. I have never laid brick before, especially with very little mortar haha.
    • Novaslo
      • Dec 2013
      • 279
      #62
      Hey Gang,
      Well I am learning yet again....I spent the weekend working on the oven. It is amazing how much time can get consumed working on this project.
      Mortar and lining things up is crazy time consuming.
      Everytime I moved my Jig, it seemed that I would move it too far. This caused a myriad of problems. Either way, I learned from it.
      In the pics you can see my arch. It is all coming together.
      I am up to course 4 after the soldier course or 5 total.
      I was able to do two courses today. Thanks in part for the Mortar tool that I bought. A Mortar bag is a game changer.
      I was able to keep my mortar moist as well as mix it right in the bag. Pretty cool.
      Any input is appreciated.
        • 5260
        #63
        Wow, tight joints. So far your flipping back front to back has caused not issues as far as I can see. Tip I learned as you go up higher and gravity becomes and issue, last brick of the day, set one brick on the next course back center and the next day you have an anchor brick to start off on.
        • Novaslo
          • Dec 2013
          • 279
          #64
          Good Tip.
          I saw another method of holding bricks that was unique. The guy in the picture took a fishing hook and a piece of line, he put a weight on the line and hung it off the back of the brick. Hooking it over to the front first.
          I can tell it will be difficult getting bricks to join the arch. However, I am up for it.
          Very anxious to get this done.
          My personality does not do well with unfinished projects.
          • Novaslo
            • Dec 2013
            • 279
            #65
            Here is a progress update....
            I have been on the saw and cutting brick as fast as I can. Today i was able to get above the arch so that is a break through. I keep learning and am getting excited to get to the end. It gets more challenging the higher you go.
            So more to come as I close the dome.
            Just about everyone I know is interested in this project. My issue is that I don't do well with stuff that is undone.
            Either way, I am making progress.
            D
            • kbartman
              • Feb 2013
              • 572
              #66
              Just caught up on your build, looking good. I really like your base slab, turned out great. Looking forward to following your build.
              Respectfully,
              KB
              My build
              • Novaslo
                • Dec 2013
                • 279
                #67
                Happy Father's day everyone. Well, I have done nothing else on my time off but build this damn oven. Progress happened today. I decided to go to third size bricks and ended up losing my battle with Gravity. It was time for a platform.
                It took me about 20 minutes to solve and I was on my way to finishing. That happened TODAY....
                Everyone was excited. My girls were home and my wife was excited to see it get closed.
                So the dome closed.
                When I got to the keystone, I was thinking about all of the great builds and kept trying to make it just right. But, as time would have it, I didn't want to spend any more of it! I kept thinking about those pizza's laughing at me and my keystone.....thinking we don't care what it looks like dumb @$$
                I thought about a lot of stuff as I finished it today. It was a good day and I am happy, more than happy with the results.
                I still need to get my body up in there and clean HAHA
                Enjoy.
                • Novaslo
                  • Dec 2013
                  • 279
                  #68
                  Front view, it felt great to clean it all out!
                  Sand out, plywood out and all ready to light a fire.
                  • Greenman
                    • Feb 2013
                    • 1123
                    #69
                    Looks good. Congrats on completing your dome. It gets more rewarding as you go along.
                    I was determined to defy gravity and that made closing the dome special for me. Your build looks very good.
                    Cheers ......... Steve
                      • 2848
                      #70
                      So the dome closed.
                      Enjoy.
                      G'day
                      Shame you weren't in Aust . Father's Day's not till September, you could save your legs,prop them up, have a beer knowing you could clean up tomorrow as you have heaps of time
                        • 5260
                        #71
                        Congrats of completing the dome. Nice feeling, time to be patient with the cure, slow and sure.
                        • Novaslo
                          • Dec 2013
                          • 279
                          #72
                          There is still a lot to do and plenty of time for curing. I will take it slow.
                          • leetheldc
                            • 255
                            #73
                            this looks great must be a good feeling completing the dome knowing all (well most) the hard work is done congrats
                            link to my effort http://www.fornobravo.com/forum/f8/7...art-20707.html
                            "95% reading this forum 5% building"
                            • Novaslo
                              • Dec 2013
                              • 279
                              #74
                              I am thinking that very thing.
                              Building the dome was a good test of stick2it let me tell ya.
                              Trying to get it done for a small party on July 5th.
                              Likely I will get close enough to cook. 😎
                              • NCMan
                                • Jan 2014
                                • 846
                                #75
                                Nice job, Darin. Congrats on the pluggin'. Can you smell the pizza?
                                My Build:
