You have made a remarkable oven, well done!
My take on oven moisture: If it is fired once or twice a week, the oven heats more quickly, gets hotter, and stays hotter longer than when Moisture builds up from disuse.
Firing the oven, even to an intermediate temperature goes a long way to controlling moisture. You can't get rid of a lot of moisture with just one firing cycle though. The solution is to use it more often. ;-)
Keep in mind that wood contains at least 8-10% moisture, sometimes a lot more. This moisture makes a more moist heat than in your kitchen's oven. There are pluses to baking with that moisture given off by the firewood. JMO
