Re: My first attempt for 42" oven / changed to 36"
Perlite is good for around 1100 C which is about double the temperature you will ever be subjecting it to so temperature is not a problem. It's strength however is pretty low, you can easily crush the grains with your finger tips. The more perlite you have in your brew the weaker it will be.
Originally posted by George_M
View Post
