Re: 36" Pompeii Build, West Lafayette, IN
No, it doesn't follow the same radius, since the door height needed to be different and it won't work following the same radius. What I did at your place in the build, was to go ahead and get my oven arch built. For me, after I got the arch built, the last few bricks in each course, where they tied into the arch, had to be adjusted slightly to make them tie into the dome neatly. I did not use the IT to set the last few bricks where they tie into the arch. It's close, but not exact. Hope this makes sense.
