Well I finally got around to building my insulated door. It is 4" thick and filled with calsil board. I will post more about it later.
Randy
Randy's dreams do come true oven build
Hello Randy
I used oak boards as the outer part of the door. Covered that with a sheet of steel. Made brackets and screwed them to the oak boards.
Then folded the inside part of the door. I filled the 4"space with FB and then pop riveted the inside part to the outer part of the door.
Worked well.
David4 Photos
Hey David thanks that sounds like a good plan. I have some of the pink board. I think it is just a little different density. I will have to get to work on that ASAP.
Randt
Hello Randy
I made a template from blue house insulating board. Trimmed and trimmed till I got a good fit in the inner arch.
David
The door should have a flange on it to fit up against the revel, that is the purpose of the revel. If you saved your arch form, it can be the template for the door. Congrats on finishing stone work, I know how tedious it can be.
Well I have finally finished with the grouting. I am glad to be done with that step. I had no problems with my skin doing all the work bare handed till I was half way through the grouting process. Then I wore the skin off a few fingers. I just liked the look I got useing my fingers better than the striking tools. And this far in I figured I could deal with a little pain to get the look I wanted.
I also finally set the vent floor bricks u left a gap of a little bit more than 1\4" and then stuffed it with 12' of 5/16" ceramic rope and then covered the top with ash. I did not want anything toxic on the floor so I thought that would be a better idea.
Now for a question. For the insulating door do you want it to fit inside the dome entry or fit up aginst the revel? I would like to start on that soon. Thanks for the help.
Randy3 Photos
Hello Randy
I made my door from a sheet of steel I got at a Big Box Store. Thin enough to bend fairly easily using angle iron as a bending form. The door is pop riveted and screwed together. It is 4" thick filled with CF board and it holds the temperature every well.
The Oak finish is home made.
The door does not get hot in fact it only gets warm when the oven is up in the 600 degree range.
David3 Photos
If the handles are fastened to the inner plate of the door then you might see the heat transmit to the handles. If fasten to the outer plate of door with 4" of cf then you should be golden.
Here is a little update. I have been working on the grouting of my stone veneer and am almost done now. I have a 3'x3'area left after I ran out of grout this afternoon. So I was very close when I thought it would take 6 more nights of work as today was #7. So I now just need to finish that up and I will be sitting in a pretty good spot to go in to winter.
I also now have the stuff to make my door so I just need to get to work on that. If I have 4" of cf board in the door do I need to worry about the Handel's getting hot?
Randy
Hey David thanks. I had completely forgotten about the face on the tree. It has been there since we got back from our honeymoon 11 years ago. My in laws put it up as a joke because my wife did not like them and now loves it.
I do have planes to make a door and plan to fill it with cf board. I still have 2 24"36" sheets left so I could probably do a few of them. I have just been short on free time lately. My 15 month old takes a lot of watching, and I think must be training for a marathon. I did not know such a little guy could run so fast and far. It makes me tired just watching him go.
Randy
Hello Randy
I was referring to the face on the tree.
Have you done an insulated door yet? It is very necessary for further cooking. Mine is 4" thick filled with CF blanket. I have also recorded the oven temperature over several days so that I can plan my cooking.
The smell as you open the door on a roast or bread is great. I have even done cookies.
David3 Photos
Hi David no I have not done anything else in the oven yet. I plan to but I do not have the landing done yet and no door.
Yeah I was thinking about the price per pizza I was thinking it was down to 150$ a pie but you might be closer at 200$ I did not keep real close tabs on what I spent.
I am also happy with the tree there it helps to shad it nicely.
Randy
Hello Randy
So at 36 Pizzas have you calculated how much they come to now?
My wife says we are down to the $200.00 pizza.
Your finish looks great.I like the tree to the right of the oven.
Have you done anything else in the oven apart from pizza.
I have done Bread, Roast, Chicken, Cookies and dried peppers. Everything was great. One firing for Piazza then Bread then Roast then cokies then dried peppers. This was over a period of 4 days.
David
Marc thanks for the compliment . You are very right that this is not just a few weekend diy project. I would bet that I have over 200 hrs invested in the construction so far. Also that does not include research and what limited planning I did. I am happy to hear you like the design I did. I had several ideas floating around in my head when I framed it up and then just kind of winged it. That is my favorite way to do projects as it lets me make changes on the fly to get the best result.
Randy
Awesome! Looks great! Love the asymmetry of the roof, how you rotated it to be square to the side of the oven. Good job with the stone as well! We all understand how much work you put into it. It's not a weekend DIY project. Very impressive. Enjoy your oven!
