Kemo's South Austin Pizza Oven
  • Unofornaio
    Re: Kemo's South Austin Pizza Oven
    Just making sure... you did add support to the little cutout section in the back right? It will not hold without it.
  • asudavew
    You are on your way Steve!
    Looking good.
    You gonna pour on Sunday?
    By truck or by hand mixing?
  • Kemo
    I have to build the outer frame and decide on the cantilever, if any, and a couple of other things. Before I pour in the concrete, Im going to jam any available 2x4 legs up under the plywood for support. The more the merrier I suppose.
  • Kemo
    and here is a quick shot of the top with wood inplace and this is how she sits until Sunday.
  • Kemo
    and then after consulting with some engineer types here at work, I decided to add some more support to the subflooring on Day Six
  • Kemo
    and Day Five:
    I had built the inner frame of the subflooring like so:
  • Kemo
    OK...day four here:
    so I have filled every other hole of the dry stack with rebar in it
  • Kemo
    Originally posted by Ken524
    That location is great. The pizza oven with the stone wall backdrop will look really nice!
    I was thinking the same...plus, it came with the place (AKA - Free!)
  • Ken524
  • Kemo
    so my next step is to pour the concrete down in the holes. I probably wont get to it for a few days...
  • asudavew
    Originally posted by Unofornaio
    woops too late now..you did all that while I was typing...wow
    Yeah!
    It was quick!
  • Kemo
    About that wall there. I'm in a townhome and thats actually a retaining wall there. Behind it is a lot of clay and I high sloping hill. I havent seen anything come out of that hole except a frog! I think its probably clogged with clay. Its as dry as a bone in there.
    We had so much rain here this summer and none of the drains ever produced anything. There should be very little, if any water comming out of that hole. Even in the hardest rain.
  • Unofornaio
  • Unofornaio
    Looking good.. and welcome to the group.
    If the pipes in the wall are for drainage from somewhere you might want to consider making a dry well for the water to go down and under the oven slab, caping them off or diverting them.
    Several tons of weight, stone wall corner, slab above surrounding grade add water from drains and you have...well, trouble.
  • Kemo
    Dave,
    I can taste it!
