Too bad that Menards is only local to MN/WI, but unfortunately they don't have the vent adapter and spark arrestor available in stores, but I could pick through everything else and find stuff that was nice.
Thomas, do you need just the spark arrestor or the entire rain cap? I ordered my cap without the arrestor, but reading the description and looking at the picture I am going to make one using the left-over stucco mesh I have. The arrestor is over $10, but you can get around 16 ft^2 of lath for around $7 at the hardware store. If the Menards one was stainless I might buy it, but it is galvanized steel (like the mesh), so a little re-purposing is in order ;-) After typing all this I see there are stainless ones available, but Menards says galvanized.
My build thread
Originally posted by JRPizza View PostThomas, do you need just the spark arrestor or the entire rain cap? I ordered my cap without the arrestor, but reading the description and looking at the picture I am going to make one using the left-over stucco mesh I have. The arrestor is over $10, but you can get around 16 ft^2 of lath for around $7 at the hardware store. If the Menards one was stainless I might buy it, but it is galvanized steel (like the mesh), so a little re-purposing is in order ;-) After typing all this I see there are stainless ones available, but Menards says galvanized.
The good news is í was able to clear my oven dome with the last firing, bad news is í have a large crack from the soldier brick half way up my dome side. Cooked my first pizza and it was awesome.
Ivan.
You can pack some mortar in there or high heat caulk if you want to, but really it won't affect anything in the long run
I used the high temp caulk as I had left over from sealing up my chimney flange and my rope around the heat break, but not sure how necessary it was. My crack is right in the back, and the first time I saw it the sun was shining through it while I had a fire going. Probably about the same size as yours was. I don't know if it was impatience, not having insulation, or just where it was going to crack the first time it got hot enough, but I am probably the only one that notices it.Last edited by JRPizza; 07-13-2018, 10:30 PM.My build thread
Thanks Guys, í had first noticed a hair line crack after my 4th day of curing and it just kept growing from there on. I will try and grind some out and fill with homebrew. Funny how í was just thinking í had no serious cracks and then this one apeared. Very cool how the dome got cleared, í thought the black soot would never burn off.
Thanks again.
Ivan
Originally posted by deejayoh View PostYou can pack some mortar in there or high heat caulk if you want to, but really it won't affect anything in the long run
The homebrew never had a chance to bond properly to the brick surface as it came off clean from the brick.
thanks again.
Ivan
