Longmont, CO new WFO build - casted over sand
I break with convention here and don't use lath. Primarily because it takes too long. Instead I use randomly mixed AR glass fibres in the render coat. Also because of the time factor I do the cement render in one single coat of around 12-15 mm thick, finished with a sponge. Then wrap the whole thing in cling wrap to keep the moisture in the outer layer, letting it cure for a week to enhance strength. After unwrapping it and some more fires to ensure the outer shell is thoroughly dry I then apply the acrylic coats.Last edited by david s; 07-13-2017, 06:07 PM.Kindled with zeal and fired with passion.Comment
Yes that's the stuff, make sure you get AR, alkaline resistant fibres. I add 4% by weight. Check this link
Appears there is no more residual water stored in my CaSi board (at least was my thesis). I had the oven hot yesterday for hours and no sign of the water seepage down thru the foamglas to the concrete hearth. I will be putting that panel of my enclosure back up today and adding the loose perlite (I hope).Comment
Cleaned out the oven today and took a brush to the inside of dome again.
Those casting ovens in the future:
Don't forget the wet newspaper. This will keep you from having sand stuck to the refractory. Sandy pizza is not a favorite of anyone! David S. warned me.....
Today I taped my joints of the vertical walls and sealed with Versabond Thinset.
I also added 6 cu ft of Perlite around dome. This gave me at least 12" high all the way around. I wasn't happy with my ability to secure the insulation blanket around the firebrick, since I hadn't cut the firebrick in the shape of the dome. So getting 4" of perlite around the firebrick (in some places more) and well up the oven dome which has 6" of blanket makes me feel that the insulation is more than adequate now.
Also got some of the perlite up on the flue area just below the chimney anchor plate, where I didn't have good coverage of the FB blanket.
Can't find the hydraulic steam vent I bought on Ebay when I was planning a dome. Decided it was overkill anyway and bought a small 2" vent and cut opening in sidewall of hardieboard.
Was thinking of using redguard on my hardiebacker since I have a flat section of roof and it's really not a good design for rain/snow. But like a shower, it would run down the outside of the cement board, but no where to go at the bottom but to pool. Would have to have a sloped counter and some sort of drainage to have it be effective. Anyone ever thought this thru for a dome design? I have the redguard already from my bathroom remodel.Comment
If I understand this correctly, you do one cement render coat that has the AR glass fibers in it. Then you do multiple finish coats (after the render coat is dry) using acrylic stucco?I break with convention here and don't use lath. Primarily because it takes too long. Instead I use randomly mixed AR glass fibres in the render coat. Also because of the time factor I do the cement render in one single coat of around 12-15 mm thick, finished with a sponge. Then wrap the whole thing in cling wrap to keep the moisture in the outer layer, letting it cure for a week to enhance strength. After unwrapping it and some more fires to ensure the outer shell is thoroughly dry I then apply the acrylic coats.
Do you (or have you ever considered) use a fiberglass mesh trowled into the base coat?Last edited by cnegrelli; 08-02-2017, 08:16 PM.Comment
Yes, but I find the best way to apply the acrylic is to water it down 20% and paint it on in successive coats sanding in between. This way you can get a perfectly spherical surface. Be careful, some products are labelled acrylic render when in fact they are acrylic modified cement renders. What you need is a 100% acrylic render that comes wet in a bucket. If it's dry in bags it will be basically a cement render.
No I've not used or seen a fibreglass mesh that is used in conjunction with render. It would have to be AR or the alkalinity in the cement will attack and corrode the fibres. The beauty of the random fibres is that you just throw them in during mixing saving a lot of time that is required when placing mesh.
Thanks. As I am not doing a spherical shape, but have corners and edges (i.e. cement board) I've got a slightly different objective.
Would you try your approach if you had this shape rather than spherical? Please see post #121. My framing makes it tough to get corner bead at the edges using traditional lath methods.Comment
This is a link re: the mesh. I think it's the same idea as adding fibers into the base coat itself, but probably more difficult! I wonder though if it would help out more on the corners?No I've not used or seen a fibreglass mesh that is used in conjunction with render. It would have to be AR or the alkalinity in the cement will attack and corrode the fibres. The beauty of the random fibres is that you just throw them in during mixing saving a lot of time that is required when placing mesh.Comparing acrylic stucco and traditional stucco is a good thing to talk about because there is a lot of confusion about the topic, due to a number of different things like multiple names for both types, different materials that are used, the price of the material and the labor involved You get the picture.There areLast edited by cnegrelli; 08-03-2017, 06:37 AM. Reason: Full link doesn't seem to post. Can click on link, then "popular topics" at top, and article on additives is there.Comment
I have been finally getting back to the finish stage. Oven is working great. I have been adding lath to the cement board outer shell in preparation for stucco. This is a lot bigger job than I had imagined and why I spent so much time looking for a way to avoid it!
I am having trouble locating a suitable caulk to go between the stucco and double-wall chimney. What do people use here? The temperature of the outside of the pipe gets a bit hot, certainly over 120F which is what the max rating is for the silicone caulks I looked at.
I need it to be waterproof and hold up to sunlight.
edit: Found the caulk that the replacement windows contractors used. XtraBond9500, and the datasheet states it remains flexible up to 425 degrees F.
Datsheet (I couldn't seem to get the pdf to link) can be found at:
choosing: XB9500-TDS-160720Last edited by cnegrelli; 08-27-2017, 08:37 AM.Comment
