UtahBeehiver  Yeah, I think Saturday was sort of my last hurrah before winter, though we usually get a couple warmer weeks during winter that I might be able to take advantage of... However, I will be taking a break to rethink my oven size...
I think I may be able to increase my dome size a little bit now that I have the overhanging hearth. I will be using 9 inch firebrick (split) for the dome. I am trying to get an idea of my overall final "dome wall" width so I can decide how much extra I really can expand. Is 2 inches of FB blanket a common/adequate amount of insulation? I keep reading that you can't over insulate, but I am just curious what is the most common insulation width on the dome. Maybe 2 inches of blanket and then 2 inches of vermicrete?
 The tapping settles the concrete and the air gaps get filled in. The issue is very minor in terms of your slab strength and utility. I tiled the outside of my foundation stand and simply filled in the rough spots along the top edges of the platform top with mortar or thinset...which ever was handy at the time. I suspect you had planned to finish the outside of the CMUs and it could be covered up at that time. Otherwise, simply make up a batch of mortar and fill/smooth out those areas. Relax, it's looking good (and very normal!)
