Les' Build
  • Re: Les' Build
    Very nice storage solution, too.
    I like the metal handles - I've had my tools outside for so long that the wooden handles had become stained and blackened. Not too appetizing...
    Had to clean them with a scrubber pad and bleach. It's already time to do them again!!!
    I presume the pooper scooper was brand new?
    Christo
    My oven progress -
    sigpic
    • Re: Les' Build
      No one would know unless you tell them... your tools look great!
      In fact I may try the pooper scooper idea. Brilliant!
      • Re: Les' Build
        Les...
        I dig the tool rack. I'm totally stealing that idea & design.
        See ALL of my pictures here:
        • Re: Les' Build
          Love those tools and just wish I had any welding skills - yours look fine to me!
          • Re: Les' Build
            Les-
            Where'd you find that brush head, Home Depot?
            I'm going to make one tonight. Though I can't weld, so I'll have to bolt on a handle.
            • Re: Les' Build
              It was online, I don't recall where but I can find out for you tonight. Also, it is bolted on. The welding I had to do was for the shovel - it needed a 90 degree bend.
              Les...
              • Re: Les' Build
                Originally posted by Les View Post
                ... the shovel and rake is a pooper scooper...
                The shovel is a pooper scooper ?
                What size dogs do you have out there ????
                Ciao Rog
                • Re: Les' Build
                  Ciao Rog
                  A chocolate lab - she was 90 pounds but we had to put her on a diet, now she weighs about 75. Didn't seem to change the size of the poop though.
                  Les...
                  • Re: Les' Build
                    once a big dog always a big dog, where the poop is concerned.
                    roflmao!!!!
                    btw really like the tools you have come up with there. i have the stainless steel to work that end when the time comes.
                    Do not meddle in the affairs of dragons, for you are crunchy and taste
                    like chicken...
                    My 44" oven in progress...
                    __________________________
                    http://www.fornobravo.com/forum/f6/s...ally-6361.html
                    • Re: Les' Build
                      Got the acrylic stucco on today. That's another nasty job - It's like working with sand that is soaked in paint, clean up is a bitch (still more to do when it dry's). I also got the first course of common brick down with the re-bar to solidify the walls. As much as I hate to do it, I think I will hit it again with the stucco - try and get a more uniform finish.
                      Les...
                      • Re: Les' Build
                        Re: Les' Build
                        I have used many materials to build this oven; super glue, gorilla glue, and finally hot melt glue. BUT, today, I used the mother of all - Duct tape. I knew it would be a matter of time, just didn't know where. When I sat my first arches, I took great pain cutting shallow slots into 1/4 wood so I could build the forms. This will work just as well.
                        Les...
                        • Re: Les' Build
                          Gorilla glue... now there's something I never heard of before!
                          Les, your dome looks fantastic on the outside, too. I love its elegant shape with just the hint of a point on top!
                          • Re: Les' Build
                            Thanks Frances,
                            It's the point that I was trying to get rid of. I moved on to getting all the brickwork done and may go back and revisit the dome. In time, I may just say "good enough"
                            • Re: Les' Build
                              Another milestone passed. Got the arch done. I'm hoping that things get a little faster from here. Tyeing into the dome is going to require a lot of grinding I'm afraid. Square's and curves don't get along too well.
                              Les...
                              • Re: Les' Build
                                so far it doesn't look like squares and circles have been a problem to you!!!
                                I still go back to how much I like the dark mortar.
                                I think I have the same grill light as you - mine unfortunately has a rusted stem - apparently I nicked the plastic covering and water found it's way in. Other than that, I like it.
                                Christo
                                My oven progress -
                                sigpic
