Les' Build
  • Re: Les' Build
    Originally posted by christo View Post
    I think I have the same grill light as you - mine unfortunately has a rusted stem - apparently I nicked the plastic covering and water found it's way in.
    Christo
    Christo - I think it's an issue with these lights. My neighbor put them in a year earlier then me, he has rust, and now I'm starting to see some as well.
    You would think that they would make them out of stainless, charge us for it, and call it good.
    Les...
    • Re: Les' Build
      Got the second flue cut yesterday - got the idea from David. Had to use a dry blade so it was pretty messy work. This is as high as I am going to go. Hopefully it draws well.
      Les...
      • Re: Les' Build
        I was getting a little concerned about the weight that my chimney is going to put on the insulation board. I did a little test. This is the front left side of my 3/4 ton GMC - GVW is 7200 pounds. I would think I'm good. It did smash the leading edge but I don't have any plans on driving onto my oven.
        Les...
        • Re: Les' Build
          Originally posted by Les View Post
          ....It did smash the leading edge but I don't have any plans on driving onto my oven.
          Les...
          Phew.
          Pizza Ovens
          Outdoor Fireplaces
          • Re: Les' Build
            Les...
            Oh, come on Les. Your oven can take it!!!
            Mike - Saginaw, MI
            Picasa Web Album
            My oven build thread
            • Re: Les' Build
              As well built as your oven is, I think the truck would take the beating, not the oven!
              So you're not going higher than this with your chimney? Or did you mean no higher with the flue tile and now you'll switch to something else?
              Your brick work looks really good, by the way. And I don't think the oven looks like a cone.
              Elizabeth
              • Re: Les' Build
                Elizabeth - I will take the brick to the top of the flue tile. It was drawing pretty good without the second section, so I think it will be good enough. In regard to the cone , if I have time, I am going to add more stucco.
                Les...
                • Re: Les' Build
                  4000 plus views - not bad
                  • Re: Les' Build
                    Les...
                    Gross approximation unless you think the load is evenly distrubuted which it is not.... makes it 1800 pounds.
                    You can get a more exact number without too much effort by measuring the foot print of the tire = this is area in square inches. Then measure your tire pressure which is in , if you use the right tool, pounds per sq inch.
                    Multiply tire pressure by tire foot print and viola weight!
                    ain't engineering fun!
                    • Re: Les' Build
                      Agreed - I just wanted to see what would happen to the product. I will probably add another 70 brick, at 2 lbs ea. that's only 140 lbs. I'm not sure I follow your calculation, as there is a variable If my tire's footprint is 8x7 and my tire PSI is 1 (a flat tire), that's only 56 pounds. That's less weight than the intake manifold alone.
                      Les...
                      • Re: Les' Build
                        Sorry to bore everyone watching the grass grow - I just want to document the process for the newbies.
                        Since there is nothing to tie the bricks to, I decided to add some steel for the second story (probably not needed). I had to fill the cavity anyways - no harm, no foul. I did put about 6 inches of high heat mortar on top of the fire brick - after that, it was type S. I am excited though, the end is in sight! And knowing that Norway has lost it's summer - I need to get my ass in gear.
                        Les...
                        • Re: Les' Build
                          Can I say again that this is just great work.
                          Thanks.
                          Pizza Ovens
                          Outdoor Fireplaces
                          • Re: Les' Build
                            Les, never hesitate to post pics - I don't think you could ever possibly bore me with your oven!
                            • Re: Les' Build
                              This is what the thing evolved into. I bought 5 more gallons of acrylic stucco today to give it a better shape and help it withstand the weather. I still need to build the vent cover (stainless steel) add the porcelain edging, and do an acid wash. My door is in process (the shop just got slammed). Outside of that, it's pretty much done.
                              Les...
                              • Re: Les' Build
                                Les,
                                Lookin' on point! Wow, super clean man. I really Like the whole layout. Are you going to paint the stucco? I can't wait to see the door.
                                Dave
                                David and Cynthia Manchester
