The next step is to apply the Superwool blanket layers. I'm going to have either 4 or 5 layers, depending on how neatly I manage to do it.
What is the recommended way to keep these clean and covered in between drying fires and until the outside layer of vermicrete/render gets applied? Do I just put some plastic over them?
). You want the air exposure while doing the curing/drying fires, so after each heating cycle & cool down, putting a tarp or plastic over it keeps it from those possible rain showers. The best way to keep it dry during the initial firing process is to move one of the canopy tents over the build when not firing (chimney heat flow can burn right through them...I know because I just moved my cover back a little from the chimney and the wind moved the heat plume enough to do damage). The advantage of putting a piece of clear plastic over the oven as it cools down is that you'll be able to confirm that you're still driving out moisture based on condensation (on underside of plastic
