32" build in Calgary, AB - pompeii neapolitan
  • On the theme of thermal expansion, generally for the service temperatures we take our ovens to, the expansion is not much of a problem because it's only around 0.5-0.7% (or 5-7 mm for every metre). However, as this thermal cycling occurs every time the oven is fired it is constantly expanding and contracting. The analogy of an expanding chest during breathing is a good one. A tight belt around the chest simply restricts free and easy breathing.
    Water elimination, expanding steam and steam spalling is a completely different issue.
    A semi-circle arch is a relatively stable form two dimensionally and improved in three dimensions, but not completely self supporting. The only true self supporting arch is the catenary arch and it is unfortunately an unsuitable form for an oven because of the low angle at the base and the high crown. In its three dimensional form the catenary dome requires no assistance from either buttressing or bracing. See "Pizza oven becomes a kiln"
    Because kilns experience more than double the service temperatures to that of an oven and the corresponding more than double thermal expansion experienced, methods of supporting the structure were developed. Ovens are not kilns, but the same principles apply. Heavy buttressing introduces energy sapping thermal mass, so lighter weight steel bracing is usually the preferred method. The greater the arch radius, the greater the outward thrust and the greater the need for support.
    If an oven cracks, and many do, it is simply creating its own expansion joint where it needs to. The usual method for refractory engineers designing kilns and furnaces, is to observe where the cracking occurs and then engineer expansion joints at those positions.
    I believe it is preferable to allow the inner oven to expand and contract freely within the outer shell, allowing the insulation layers to act as the expansion joint. But the firing of an uninsulated oven is asking for trouble because of the huge temperature difference between the outer and inner surfaces of the inner oven.
    Click image for larger version  Name:	IMG_2428.jpg Views:	0 Size:	67.4 KB ID:	472607 Click image for larger version  Name:	IMG_2429.jpg Views:	0 Size:	66.5 KB ID:	472608
    • As mentioned before, the left red line point needs to intersect the vertical center of the brick face or you get a cumulative error as you move up in the courses resulting in a stepping of the brick course. It is cumulative and gets worse as you go up.
      • Originally posted by UtahBeehiver View Post
        the measurement I made applies to any line on the clamp as its perpendicular to the clamp jaw, and when I place the brick, I will place it such that the centre of the brick is at the centre of the clamp jaw - thank you. I can slide in a board of same width as brick with edges locking it to clamp jaw that it grantees brick in centre if placed within its width.
        I had a field trial today and I realized the following:
        1) with my clamp bar screw on the outside, after placing a brick(I did it dry of course), when trying to move the tool upwards it will knock the brick away upwards with it because of the angle lip. the only way regardless of where the length measurement line hits the brick, to get the tool not to knock the brick away is to have a screw on the inner side as well.
        so, as I am missing the screw on the inside, I will try tomorrow to use a 1/8" wood board shim that I place between the inner bar clamp jaw and the inner brick face and might have to put on it slippery substance like a parchment paper , so after I finish placing the brick and unscrew the outer screw, I will pull the 1/8" board shim may be sideways, while it may still shake it a bit it might be less especially if i pull it in the direction where I want the brick to compress for its head joint. that one is what I could use to help aid centre the brick on the clamp jaws.
        2) i am not going the route of using welding to make my custom tool because once I build the first-2nd course and reach above the hearth, I could use the quarter circle template that I made to align the brick if it shakes after removing the trammel clamp upwards.
        I am going next, to adjust the trammel length to be correct with the introduced board in jaw, and then remove all hearth bricks or most of them in centre to install trammel above insulation, build my 1-2 first courses of the dome using the trammel and then put the hearth and protect it by cover and then start building using the template not trammel. might be something different like delaying laying hearth until couple more courses just not decided how yet:
        1/2 brick high is 2.625"/2 = 1 5/16", therefore I should draw a line from top of clap jaw down 1 5/16" and then 16" to the axis, and use 1/8" board shim to slide sideways
        but honestly, I forgot that I have a release button at the inner jaw clamp so that solves the issue of not having a screw, still the issue of the angle between axis line to jaw and the jaw plate are not perpendicular need a board shim to correct it
        • Today, I finished mortaring the first course of my dome (spring line course#0, which is 2.625">>2.19" on top face, bottom un cut and 4.5">>3.52" on left and right), I used parchment paper under the dome bricks so no joint mortar will touch the insulation mortar coat, I only put mortar on joints, I did not put any mortar bed or slurry at all, just parchment paper. I however to seal the cooking chamber from dome outside and render after parchment burns, I put a thin mortar layer outside of the dome brick where brick meets insulation coat so that its sealed, unless it cracks from gas pressure, its fully sealing any gaps between parchment paper and brick/insulation coat (of course I removed any excess parchment paper with a sharp tool before sealing with mortar. I then put the pre-cut hearth bricks in place. I filled the gap between the hearth and dome bricks, which was a bit larger than intended of 1/4" with brick cut shims to keep the large gaps closer to 1/8", I plan after firing the oven and having ash, to vacuum everything in the gaps and fill it with pure fine ash.
          I am now ready to build next course, course#1 (2.625”>>2.05” top/bottom, and 4.5”>>3.52” left/right), but after I set up my trammel or template tools above hearth as my sphere cap centre is 2" below hearth brick top surface, and after I place the actual stainless steel banding snug (to be tightened after firing while oven is hot and expanded, and after I mortar my throat and mouth arch legs to mark the space for dome build
          here are the picture from today's progress:
          ​ Click image for larger version
          • I , today, wrapped a 1/4" ceramic fibre paper around the dome bricks course#0 and then applied two straps of stainless steel banding (0.03" thick 3/4" wide), I tension-ed a little just to keep ceramic fibre paper in place with some compression, I did not even close the clip, will re-tension after oven firing when oven is hot, before applying ceramic fibre mat and dome render.
            I , as well today, mortared the bricks for the archway , first course (hearth level) only, making sure that they are levelled
            I did seal the gap between the dome brick and archway first course with about 1/8-1/4" refractory mortar to seal ceramic fibre paper in archway (from the dome banding paper) , however I later scrapped it not wanting to bond the archway to the dome, I will later on next work on it put a much thinner layer to seal the ceramic fibre that is too thin to become a bond
            next, I plan to position the arch forms and start cutting and dry fitting all the three arches, before building any further dome bricks, I am considering completely building the inner throat arch (only) as well as the flue gallery and mouth (outer ) arch legs (only) as well before building the dome bricks.
            pictures from today's work:
            Click image for larger version  Name:	IMG_9193-s.jpg Views:	1 Size:	1.02 MB ID:	472658
            Click image for larger version  Name:	IMG_9192-s.jpg Views:	1 Size:	607.0 KB ID:	472659
            • Be careful
              "firing of an uninsulated oven is asking for trouble because of the huge temperature difference between the outer and inner surfaces of the inner oven"
              There are many reports of ovens cracking because builders have fired them with no insulation in place.
              • It looks like for dome course#0, I used exact cut however also used 1/8"-1/4" mortar thick as the cuts ended up smaller than the desired(I allowed it for mortar) resulting in using only 27 half bricks instead of 29 half bricks . so I now calculated the new brick cuts when using 1/8" mortar and I will tune my jigs to get exact final cut:
Name:	arch cuts including mortar thickness.jpg
                • I placed today the cornerstone of the inner arch, I noticed that , the stone is connecting the dome to the archway base on top surface (archway hearth), wondering if I should use my angle grinder to remove that mortar joint line between the archway brick and the dome course#0 brick shown below, or likely it wont bridge much heat as its only 4.5"x4.5" - there will be 1/2" fibre glass rope gasket between (in front of ) the inner throat archway legs and voussoirs and the archway arch legs and voussoirs , just this first base brick is not, thinking this arrangement would keep the hearth clean of multiple gaskets and for food sanity...
                  Click image for larger version  Name:	IMG_9207-s.jpg Views:	0 Size:	1.25 MB ID:	472725
                  Click image for larger version  Name:	IMG_9191-s.jpg Views:	0 Size:	1.32 MB ID:	472728
                  Click image for larger version  Name:	image.png Views:	2 Size:	35.6 KB ID:	472729​
                  • I have refined my trammel now its much better, it will need more sturdy nuts and bolts which I will put when I have a visit to the hardware store:
                    1- now vertical axis is almost same plane as brick centre when its in clamp jaw
                    2- the line from the vertical axis to the brick face is perpendicular
                    • That is much better. Should work good with no stepping error.
                      • I had to modify it further, removed the L angle steel as they are very high and placed the trammel vertical axis directly in the lazy Suzan bearing by twisting the holes up. now its 5/8" exact high, which is exactly what I need to place it directly on insulation without the need for any levelling, I have to support it by creating a hollow square in a wood board where when lazy Suzan lower plate get stuck in the square it can't move , while top one does, the board has to be thin near the bearing plate:
                        • Finally the build started, I cut bricks to desired shape (which was actually a lot of work to cut enough for just one course, it went will, just one thing , I should have dry fit before I mortar, resulted in one course loosing staggering with the one below so had to leave gap to keep staggering, tomorrow will cut one and fill it while cutting for the inner arch intersection. it could easily take a full day to cut and build just one course:
                          1-pictures of trammel mounted (actually mounted loose, I can re-put after each brick)
                          2- picture of build of part of course#1
                          3- picture of dome cut brick (7 cuts total: cut in half->Left wedge->right wedge-> top taper -> top taper remaining thickness (10" saw not deep enough)->bottom tapper-> bottom tapper remaining thickness)
                          4- one of the bricks got stuck by the hearth and because how the trammel is pushing on the hearth, by time I was trying to fix it the mortar was hard so it did not adjust very well, but will ignore as its less than 1/4"-1/2" off course (outwards)
                          Click image for larger version  Name:	IMG_9282-s.jpg Views:	0 Size:	1.17 MB ID:	472787
                          Click image for larger version  Name:	IMG_9283-s.jpg Views:	0 Size:	1.25 MB ID:	472788
                          Click image for larger version  Name:	IMG_9284-s.jpg Views:	0 Size:	1.12 MB ID:	472789
                          Click image for larger version  Name:	IMG_9286-s.jpg Views:	0 Size:	1.01 MB ID:	472785
                          Click image for larger version  Name:	IMG_9288-s.jpg Views:	0 Size:	826.5 KB ID:	472786
                          • I had finished 1st course and about half of 2nd course, next would be third course and inner arch:
                            Click image for larger version  Name:	IMG_9295-s.jpg Views:	0 Size:	737.8 KB ID:	472809
                            Click image for larger version  Name:	IMG_9298-s.jpg Views:	0 Size:	593.7 KB ID:	472808
                            Click image for larger version  Name:	IMG_9299-s.jpg Views:	0 Size:	533.9 KB ID:	472807
                            • Here are a couple tips. Make any width correction in the front half of the dome, no one will ever seem them one the oven is done. They only peek through the door when the oven is going. Second, as you move up in courses, at the end of the day, lay one brick on the center of the back of the dome on the next course. This will give you a solid anchor to start from when you start positioning bricks the following day. I used a rubber mallet to position and move the bricks when setting.
                                Here are a couple tips. Make any width correction in the front half of the dome, no one will ever seem them one the oven is done. They only peek through the door when the oven is going. Second, as you move up in courses, at the end of the day, lay one brick on the centre of the back of the dome on the next course. This will give you a solid anchor to start from when you start positioning bricks the following day. I used a rubber mallet to position and move the bricks when setting.
                                Thanks for the tip, I almost did not think about that the position of the width correction brick matters on the inside more than the outside, I was working under heavy rain for past 3 days wet and cold... my cut brick is 3 3/8" (inside) and 4 3/8" (outside), with my Thermobond 915 refractory mortar minimum thickness is 1/8", I end up somewhere between 1/8"-1/4". so , I always started from the back centre of oven however after about 8 bricks, the staggering vanishes and the brick aligns on the outside: 4 3/8" brick+~1/4" mortar=4 5/8", so 8 mortared bricks yield circumference of about 37", which is equivalent to 8.5 brick widths exact(this is when the half brick was left at start becomes gone, from the 0.5 of the 8.5). I therefore has to have a correction brick every about 8 bricks(for one course pattern, the one on top will end up every about 6-7 bricks because of arch). I have been having them currently , when starting from the back centre, at the back corners and near the inner arch.
                                I will try to fix it by having the correction brick be laid first instead of the full brick at the front half instead of the back centre, then go toward back and front and correct again where needed.Though, I think nothing will work as if I shift the correction to front corner then there will be another one needed in the centre back, which is worse than the back corners, that's because of how my bricks widths are and that I need more than one correction brick (about 3 ) per one course.They just gonna scatter somewhere. a best I do is to have the correction brick be the widest possible.
