  • I appreciate this dialog. My gasket is not showing physical signs of breaking down, which makes sense as the temps are not that high. But, off gassing occurs at much lower temps.
    It looks like the better option would be LavaLock RTV650.
    Once I get my v2.0 insert made I'll experiment with no door gasket and with the LavaLock and record both the door temps and heat retention over time.
    It may be that a door gasket does not provide a material improvement.
    I'll report the findings on my build thread.
    • Originally posted by Giovanni Rossi View Post
      This Silicone is not an insulator. It will conduct heat:
      fibreglass: R-Value (Per Inch)Roughly R-2.2 to R-4.0 (depending on compression density)
      LavaLock RTV650: R-Value Negligible (Solid silicone transfers heat quickly via conduction)
      • Originally posted by IH123 View Post
        Conductors and insulators are relative. R values are calculated as the reciprocal of conductivity values.
        Silicone is not particularly conductive.
        Check the Engineers toolbox for conductivity of materials.
        eg.
        Perlite 0.03 W/(mK)
        Silicone 0.2
        Timber 0.15
        Firebrick 0.47
        SS 304 14.4
        Carbon steel 59.0
        so while silicone is 6X more conductive than perlite, carbon steel is 295X more conductive than silicone.
        Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
        • Heat Loss at 600°F Inner Temp Heat Loss at 800°F Inner Temp
          3/16" A36 Carbon Steel ~882,000 BTU/hr·ft² ~1,134,000 BTU/hr·ft²
          1/4" LavaLock RTV650 ~3,675 BTU/hr·ft² ~5,060 BTU/hr·ft² *(will break down)
          1/2">>1/4" Compressed Fiberglass Rope ~880 BTU/hr·ft² ~1,520 BTU/hr·ft²
          Thermal Conductivity (k) at 600°F
          3/16" A36 Carbon Steel 44 – 46 W/m·K
          LavaLock RTV650 Silicone 0.2 – 0.3 W/m·K
          Fiberglass Rope Gasket (1/2" compressed to 1/4") 0.05 – 0.07 W/m·K
          heat loss compared to the steel door at 600F is:
          silicone gasket: 240 times less
          fiber glass rope: 1002 times less
          ​which is actually about x4 not even x6 if pure perlite
          • Hey fellows, sorry to have opened this can of worms and to have temporarily hijacked this thread. I'm not sure the magnitude of the differences are all that material to this application.
            I'm going to make this my final post and then sign off from commenting on this build in the future.
            I shared the gasket solution as it made sense for me and has worked well and I thought it was a good alternative to a rope product that I had tried and discarded because of shedding fibers.
            I was happy to have been cautioned on my choice of material and that led me to research a better alternative.
            Choices made:
            I was trying to solve what I perceived to be an issue in my particular situation.
            While I was getting great heat retention with just the steel door, I wanted to push that as far as I could for multiday cooking.
            My steel door is designed in such a way that it needs to be tilted to pass through the exterior arch. This made it impossible to add any thickness to it if I wanted to try to insulate it.
            This led me to the idea of a separate slide-in insert. Again, I was intrigued by the history of using wooded doors. My insert is a wooded box with insulation inside.
            My lack of knowledge led to an early failure that I have learned from.
            The issue with an insert is that it needs to be sized so that it doesn't bind in the arch due to expansion of the wood as it heats or the contraction of the arch when it cools.
            Accounting for this means there is a small gap around the sides and top that heat can escape from.
            Since the steel door doesn't fit tightly against the inner arch due to slight variability in the bricks and mortar joints, I was looking for a substance that would remain flexible and tolerate the high temps.
            That's how I landed on the silicone gasket.
            While I am going to try another product, and may decide it is of little additional value, I'm honestly not that concerned using the gasket in my application.
            While the top of the dome far exceeds 1000oF during a pizza session, once the dome comes to equilibrium, the internal wall of the dome never exceeds 550oF.
            I can't remember exactly, but any time I've shot the exterior of the inner arch, I believe it's somewhere in the 300's.
            If there is any off-gassing, I'm hoping those substances will follow the warm air up the flue.
            IH123, good luck on the rest of your build. I will follow from afar since I make it a habit to read every post on the Forum.
            • I today assembled the steel door using maple dowel to create the handles, bare without any insulation and will likely use it as is for a while. for now, it will close the oven and prevent insects and rodents from nesting in it over winter. I got other things to work on next spring. I rather spend some time making sturdy all metal Andiron, log management stick... and so on on top of oven pending work:
              0)close cmu block vent using stainless steel mesh and mortar
              1)create dome buttress and arch buttress, use concrete vibrator- keep oven dry, cure
              2)install chimney and rain cap with spark arrestor, re-level base adapter first as it might settled during long winter freeze
              3) adjust door for tight close using fibre glass gasket or refractory mortar, put mortar on all inner arch lining except floor, then with little oil on door=> close it plumb/vertical and hand vibrate until it creates a matching surface => then gently remove to create a perfect matching other face after it cures
              4)insulate dome with ceramic fibre blanket, also archway( last chance to install thermometer probe )
              5) fire cure the oven slowly while dry
              6) adjust dome banding tension while oven is hot, keep it snug while hot
              7)apply perlite cement render
              8) cure again for the perlite render
              9) apply water repellent breathable paint/ protection/layer
              10)create and install aluminum roof shingles roof dome, should be strong to withstand snow and ice
              11)put granite counter tops for landing
              12)stucco and water proof concrete base, cmu walls, and top slab against rain, snow, and ice
              ​and here are the last pictures of this year, will continue the build next year:
              Click image for larger version  Name:	IMG_9874.jpg Views:	0 Size:	418.3 KB ID:	473459
              Click image for larger version  Name:	IMG_9878.jpg Views:	0 Size:	394.4 KB ID:	473457
              Click image for larger version  Name:	IMG_9881.jpg Views:	0 Size:	524.3 KB ID:	473458
              Click image for larger version  Name:	IMG_9885.jpg Views:	0 Size:	1.00 MB ID:	473461
              Click image for larger version  Name:	IMG_9887.jpg Views:	0 Size:	1.38 MB ID:	473460
                Choices made:
                Thanks for all the tips
                • You’ve got all the hard work done, not too far off cooking, good luck.
                  • after long thinking on how and what best way and product to installing a permanent thermometer that measures pizza cooking temperature, I landed on a K-type thermometer with probe. I avoided thermo well ones because they require large diameter hole, ceramic fibre insulation, and likely will stay at least 1/2" away from the brick surface as the hole if penetrated into cooking chamber could leak air/heat, or fibre dust interchangeably with render . while using infra red thermometer satisfies the basic necessity of knowing the temperature, I chose not to depend on it because if I am cooking rather have something else hold the thermometer for me. so the design that have the following features :
                    - can be removed and replaced any time plug-and-play
                    - simple and cheap
                    - accurate and reliable
                    - high heat and temperature range
                    - can be removed completely if needed one day
                    is a K-type very long thermo couple probe and reader such that the probe will penetrate the outer arch, pass through the flue gallery arch, and into the inner arch and then extended hanging out into the dome few inches to be just where a thermometer probe tip need to be facing the exact flame and air that the pizza will sit under. leaving 1mm extra gap in the drilled hole, a 1/4" (about 6mm) hole allows a 5mm stainless steel sturdy probe to be inserted without the need for any ceramic fibre paper insulation or whatsoever as that path is a smoke exist and with inner arch throat opening of mine is 14 3/4" x 8 7/8" , that gap is almost nothing. even if oven door is closed, the leak from around the door seams is probably much more.
                    I therefore loved that design and purchased the following:
                    - 5mm (diameter)x 500mm long probe that can measure from like -40c to 1300C (not F, its Celsius) , food safe , stainless steel
                    - reader , digital uses 9 volts battery with plug that can be easily plugged or not any time just like any household appliance (I purchased two so if one fails I got another)
                    here are the pictures and the plan, any thoughts? I feel very excited about this design as I never seen it but I think it should work (picture position of probe and reader are approximate and suggestions, not final or accurate, just for illustration of the design):
                    Click image for larger version  Name:	1.jpg Views:	0 Size:	288.1 KB ID:	473606
                    Click image for larger version  Name:	2.jpg Views:	0 Size:	345.5 KB ID:	473607
                    Click image for larger version  Name:	3.jpg Views:	0 Size:	761.5 KB ID:	473608
                    • here are the drilling I made:
                      special tools:
                      -BOSCH BM2008 1/4"X13" Fast Spiral Rotary Masonry Drill Bit
                      -BOSCH Daredevil DSBE1012 12 in. Extension
                      - 1/4" masonry bit 4" long
                      - 1/2" masonry bit 6" long (wiggle it to achieve about 3/4" diameter or use 3/4" if availble)
                      process:
                      1) locate a path where the hole won't exit the dome to outside, ends inside the cooking chamber, and be not in flue gallery way, as well as in a position (depth and height) near where pizza will be put
                      2) drill the outer mouth arch on determined position with the 1/4" x4" bit, then use larger bit (about 3/4") to make it big enough for the extension tip to slide inside
                      3)use the 13" drill bit to drill as much as possible into the inner arch, a 1/4" hole
                      4) attache the extension cord and drill bit together (total is about 23" long ) and drill all the way until drill bit exists into the cooking chamber, repeatedly pull out to extract brick debris as needed as it could jam from too much brick grinds that it won't drill if not cleaned
                      5) vacuum all the debris using shop-vac and a brush
                      when weather is above freezing at night (in summer) :
                      1) fill the outer arch 3/4" hole (3" long) with refractory mortar
                      2) slowly insert the 1/4" drill bit , turn the drill bit one turn every 30 minutes or so until it comes out clean turning the 3/4" diameter hole back into a 1/4" hole
                      3) after it cures, re-drill with the 1/4" bit to ensure enough uniform diameter
                      4) insert the probe (50cm) all the way without any insulation or wrapping, a ~0.7mm((1/4" hole - 5mm probe) / 2) gap all around is enough for expansion and has negligible heat loss or air exchange
                      when my probe is delivered in next few days, I will post pictures of it
                      ​pictures of the drills :
                      Click image for larger version  Name:	Untitled.jpg Views:	0 Size:	23.1 KB ID:	473717
                      Click image for larger version  Name:	IMG_0010.jpg Views:	0 Size:	882.3 KB ID:	473715
                      Click image for larger version  Name:	IMG_0011.jpg Views:	0 Size:	653.2 KB ID:	473714
                      Click image for larger version  Name:	IMG_0012.jpg Views:	0 Size:	337.5 KB ID:	473713
                      Click image for larger version  Name:	IMG_0013.jpg Views:	0 Size:	933.9 KB ID:	473716
                      • I received the 50cm thermocouple probe and tested it up to 650c on gas flame , I then inserted it in the oven like if its in final position, there was only about 2" inside the dome air and everything else past it is in brick so I am thinking of getting another longer probe (they have 1000mm ones), only after I try the 50cm one on real firing compared to infrared one. The internal brick temperature might provide a correct reading better than a transient flame or flash of hot air deep inside:
                        Click image for larger version  Name:	IMG_0038.jpg Views:	0 Size:	1.14 MB ID:	473791
                        Click image for larger version  Name:	IMG_0044.jpg Views:	0 Size:	1,017.1 KB ID:	473792
                        Click image for larger version  Name:	IMG_0046.jpg Views:	0 Size:	1.10 MB ID:	473793
                        • K type thermocouples, the most common type, are primarily designed for higher temperature applications like kilns and furnaces, with components that are tolerant for service temperatures more than double what we require. They therefore are usually more expensive and are usually provided with a porcelain sleeve to protect the inner wires and require penetration into the inside of the chamber of around 50mm (pic 2). So to use one in a WFO makes it vulnerable to damage from tools and bits of wood frequently being poked into the cooking chamber. The principle is that as heat passes from one metal type to another a small electric current is produced, so connection to a sensitive voltmeter can be easily and accurately calibrated to read temperature. Earlier versions (like the one attached pic 3) from the 1970s, which require no power for their operation, have now been replaced by ones with digital displays that make temperature increase and decrease rates instantly indicated as the numbers roll over and can also be programmed and coupled with an electrical control for heating element energy input. These digital display units do require either connection to power or a replacement 9V battery. Over the years, just as all electrical equipment fails, I have replaced two of these digital display units for kilns, yet my trusty, ancient, unpowered analogue display unit still operates flawlessly and it's the one I use for my current kiln.
                          Installing a thermometer on my first mobile oven (first pic: probe without sleeve), I selected a thermometer with a capacity to 500C and decided to protect the probe with a 1/2" copper tube, the point of the tube and probe flush with the inside surface of the inner dome. It worked well, but kept on pushing the read out display and probe out of the dome a few millimetres for each firing. When it had pushed it out by about 12mm, I concluded that it was the expanding copper sheath, firm in the hole when cold, gripping tight onto the surrounding refractory of the inner dome as the inner dome itself expanded, consequently pushing the probe and display out past the outer shell. On removing the probe and enlarging the hole slightly, I replaced it and had many years of trouble free operation. Lesson learned, don't have your probe too tight in the inner dome hole.
                          Most oven owners are pretty obsessed with temperature, but become far less so with experience. I find the best indicators are the black carbon burning off the inside of the dome (300C) and a hand held to the outside shell. In addition I sometimes use a cheap bimetal oven thermometer that can be placed in the centre of the oven to read air temperature exactly where you want its measurement. Meat probe thermometers are also very good, measuring the temperature inside the roast.IR temperature guns, while accurate can be quite misleading when used for cooking because they are reading the surface temperature and give a wild variation of readings depending on where the temperature is shot.
                          Wood fired ovens are really quite forgiving regarding temperature, I think primarily because they cook using radiant heat.
                          Hope this helps.
                          Click image for larger version  Name:	IMG_2577.jpg Views:	0 Size:	99.7 KB ID:	473816
                          Click image for larger version  Name:	IMG_2579.jpg Views:	0 Size:	101.2 KB ID:	473812 Click image for larger version  Name:	IMG_2578.jpg Views:	3 Size:	70.9 KB ID:	473810
                          • There is no other probe or thermometer that can measure up to 1000F and is long enough to be inserted all the way from the mouth and into the throat of the oven other than K-type (two metal) probe:
                            1- analogue ones have short probe , can't be used in archway. while I could use a thermowell, with thermowell hole stops about 1" before dome cooking chamber , I'd rather not as the thermometer itself has to pierce into the render and dome insulation and actually costs a lot between stainless steel well pipe, probe and insulation and so on.
                            2- I bought my probe for just about $23 CAD including shipping directly from China, the LCD display is about $7 CAD including shipping - the cheapest it could get for an industrial scale thermometer
                            3- The method of inserting the probe through the oven's mouth-archway is very clean as at any time or even moment, I could just pull the entire thing out and replace it even if I am cooking without having to change anything in the oven. thus I can clean it from carbon build up, the fact it can withstand 1000c means any build up can be burned out (cleaned) using a simple flame
                            4- there is no need for porcelain/ceramic wrapped probes, it will unnecessary increase the diameter without adding rigidity (metal is stronger) , and it could shed hazards into food cooking area. the k-type probe is of stainless steel casing so its inert food wise
                            if anyone is interested I can share the link of where to buy.
