Re: new build in werribee
Hi Dennis the floor is layed on 6 mm sand/fireclay decided it didn't need to be wet [so a dry mix] and was easier to lay the tiles due to the tiles being used and the horror stories I had read on calsil absorption rate and since discovered.
I am mortaring the outside course in to bring the height to the same level as the Hearth, hence the comments about the calsil and it being a sponge.
Arrrh it was you Dave, that mentioned that in previous posts, I just couldn't find it, thx. Will try it today 'any brand in particular'
just like greasing a cake tin before putting the mix in.
Thx Allan I have noticed that and will adjust it today. In the interim I have been using cardboard to level it whilst I check everything.
As for the soaking of bricks.... if they are not soaked the calsil and firebrick was simply sucking ALL moisture from the mix, instantly, making it completely unworkable. I mean completely unworkable. The calsil [the fire bricks had been soaked] acted like a bloody sponge. That's why I threw a scrap piece into water it was completely saturated in less than, 5-10 seconds.
Also I am NOT a bricklayer with 30 years experience and I need a little more time to get it all aligned. Especially when moisture is sponged out in less than 3 seconds no matter how wet the mix was.
David [and Wayne] as usual all information ready at hand, thankyou I have actually read that link in my research, and it made for interesting reading.
Thanks guys all comments they are really appreciated.
just like greasing a cake tin before putting the mix in.Thx Allan I have noticed that and will adjust it today. In the interim I have been using cardboard to level it whilst I check everything.
