Originally posted by smeltitdeltit
View Post
spacings are 300 mm centres and the steel frame was made from 50 x 50 x 4 mm gal angle with centre supports 50 x 4 mm galv flat bar. The strength of the frame was fine and I've retained it for the rebuild.
The first stand I made for one of my ovens was made with rolled hollow section, but I felt it had too much flex and now build them with the 4 mm thick angle. The strength and stiffness of the stand is dependent on the size and weight of your oven, (mine weighs 250 kg.) Adding diagonals to the stand will strengthen it heaps.
