new build in werribee
  • deejayoh
    Re: new build in werribee
    John - if she shorts you, you can get it here in the US you know...
    Amazon.com : Vegemite 220g Jar : Nut Butters : Grocery & Gourmet Food
    Vegemite Spread | World Market
    might not be as exciting - but perhaps more reliable!
  • GianniFocaccia
    How many Jars will your daughter be bringing back
    Sorry Colin, just caught this...
    It's hard to tell. Knowing my daughter, I predict she will fill any remaining space in her two large suitcases with clothes and bring me back an 8 oz teaser jar. I'll have to be really careful with it!
    Colin,
    Can't say for sure if farmed or wild caught, like here in the States, farmed and wild caught salmon taste different but also cost more. I guess you get what you pay for. Good luck on the top brick. I am sure it will be in the same league as the dome plug. I still have some copper work to do but the weather has been too hot to accomplish much.
    I'm not sure I understand what you are doing. I can't see why the top brick of an outer decorative arch would see such high temperatures, but I don't know your design. I cast my decorative outer arches in concrete and have never had a failure, although I do make the inner one inch or so with an insulating concrete and the whole arch is separated thermally so there is little conduction and it never gets really hot.
  • oasiscdm
    Hi David
    Thanks for that much appreciated. The paver in question is for the decorative arch. Its what I'm doing to it that requires firing again and I need a paver at least 400 x 400. Yes a concrete paver...... well, was simply useless didn't think of that when I picked it up I assumed they were all fired. WELL THAT THOUGHT WAS VERY WRONG.
    The pavers I found have been fired at 1100c. Checking with paver manufacturers over the last week not all Clay pavers are fired to that temperature. Since the glaze I am using requires at least 1100c am thinking the Paver I am referring from Claypave being fired at 1100c will in fact withstand another firing so am hoping will serve the purpose I have installed for it.
    Fingers crossed
    Colin,
    You need to use a fired clay paver. If it was a cement paver that may be a reason it failed. All clay pavers are fired, otherwise they'd turn back into mud as soon as they get wet. Even a fired clay paver may not be suitable because it has been designed to be walked on not used in an oven. That doesn't mean it is unsuitable, it probably will be ok, but there is no guarantee because the complex mix of ingredients of any clay body used in a brick will not be available to you. Likewise the temperature the brick is fired to is no guarantee of its suitability.The higher it is fired does not necessarily make it more thermally shock resistant in fact the opposite is sometimes the case.
  • oasiscdm
    Well I have finally sourced a paver that should be able to be fired so here I go again TAKE 2.
    Doing some other finishing touches to WFO this weekend.
    Adding some Hebel under the existing Hebel base so that the base thickness is the same size as the rest of the base.
    Adding a layer of chook wire for the next coating of Dome render.
    If possible a layer or two of Render.
  • oasiscdm
    Hey Craig I might give that a go.
    Russel farmed or wild there is a difference.
  • BOOMERS WFO
    The trick to Vegemite is to spread it really,really thin on toast when you first have it to get use to the taste, not thick like peanut butter.
    I use a teaspoon of vegemite when I make gravy for roasts. Adds a fantastic depth to the flavour and colour to the gravy.
    Cheers
    Craig
    I quite enjoyed the barramundi when I visited Cairns and Port Douglas earlier this year. Almost ate it every night. The SWMBO ate skippy, she is the meat eater.
  • oasiscdm
    I don't mind snappierBut wild barramundi ,. Now that is a even more delicious fish.
  • GianniFocaccia
    Colin,
    This looks delicious, and (true) snapper is one of my favorite fishes to eat.
    thanks!
    John
  • oasiscdm
    Originally posted by GianniFocaccia
    Thanks Dave. I actually tried Vegemite a few years ago and did not like it. I kept at it though, and quickly learned it is wonderful stuff. I went through the small jar in no time, but haven't replenished it because its $10 for a tiny amount. I especially like it on toast.
    Now stock - that is a grand idea and I will definitely give that a go. Thanks!
    John
    Hey John
    here is the link for that recipe that uses Vegemite.
    Salt and Pepper Snapper with Mustard Emulsion and Charred Cucumber
  • oasiscdm
    There was a recipe on master chef Australia using vegemite.last week I believe.part of Heston Bloomfield week 1st or second episode. Will look it up and post when not in car
  • GianniFocaccia
    G'day
    Tell her just a small jar. After you find its a bit of an acquired taste ( not like chittlins) you find it makes a great stock. A teaspoon with a pint of water tones it down enough to appreciate.
    John
